Results 1 to 8 of 8
Thread: Is there a quick reference cheat sheet floating around?
    Apr 2015
    Las Vegas, NV
    20
    All:
    I have found all of the info required to handle pool chemistry, but is there a quick reference floating around? Something like this:
    FC - between 1 and 4 PPM
    If low, add...
    If high, wait it out...
    pH - between .... you get the point...
    I can put something together quick enough, but before I re-engineer and op test a new wheel...
    Cheers,
    Ed
    7,500 gallon, funky kidney shaped, Hayward Cartridge filter, no heater, partial sunshine
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Is there a quick reference cheat sheet floating around?
    If you set up poolmath with chlorine source and pool finish in the last row of the table, it will autofill suggested levels for you and do the math to tell how much of each you need to add. Although one also needs to look at Effects of Adding Chemicals down lower, so one doesn't lower pH to 7.2 with MA and then add a bunch of CYA which is also acidic, or baking soda and soda ash to fix pH and TA individually but which will also drive TA far too high.
    Apr 2015
    Las Vegas, NV
    20
    Right, been using pool math, just looking for a 3x5 card that keeps me from walking back and forth from the garage to the pool... I can type it up...
    Richard320's Avatar
    Jan 2010
    18,988
    I suspect that in a month, you'll already know how much acid and bleach it takes to make your adjustments without even going near poolmath. It shouldn't be hard to figure out how much bleach it takes to raise FC by .5's
    pH adjustments also require TA to calculate, so you're stuck using poolmath awhile until you get TA settled.
    You'll learn your pool's personality quick enough. I know how much acid I need to add for every inch of refill water I add, and I just dump it into the hose stream which is right in front of the return.
    Apr 2015
    Las Vegas, NV
    20
    Correct, but it seems too easy. I told my wife all she needs to do is add 20 oz of liquid chlorine a day, she told me I needed to go hire a pool guy again. But, pool sparkles! And I don't smell like chlorine every time I get out of it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Richard is right on. In my pool, 121oz of 8.25% is 3 ppm. It's pretty easy to add 1/3 jug, 2/3/ jug or the whole jug, depending on how many ppm I want to bump up. I never measure ounces of bleach. Close is close enough for me.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Apr 2015
    Las Vegas, NV
    20
    Perfect.... Thank you, nice to have missed it... I will add in a column for remedies...
