Results 1 to 8 of 8
Thread: High TC
    Jun 2015
    Columbus Indiana
    6
    Unhappy High TC
    Using pool master 5-way test kit.
    Free Chlorine test was off the charts after one minute there were orange particles floating. When I checked the ph level it turn yellow so I'm assuming this means non-existent. And I couldn't get a change in color with alkalinity test even after 25 drops. Please help!!!
    45,000 gallon, in-ground pool. Hayward-200 sand filter. Hayward chlorine feeder.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: High TC
    Welcome to TFP!
    Are you using your chlorine feeder, or have you manually added chlorine? How does the water look?
    With your test kit, if you have high chlorine you should add two drops of solution #4 as the first step in the pH test. Did you do that? Even so, high chlorine interferes with pH testing, so I'm not overly worried about that now.
    Any idea why your chlorine is so high?
    You really need to get a better quality test kit. We recommend the TF100 at TFTestkits.net.
    Support the site
    Jun 2015
    Columbus Indiana
    6
    Re: High TC
    The water looks great. Clear. I have been using a feeder. Had trouble with no chlorine int eh pool so I turned up the dial. Then *insert excuses here* so I hadn't tested it in a couple weeks. I re tested with the additional drop. It's not as frightening low as I thought but it's below 6.8. I also have the HTC strip test. It showed alkalinity at about 40ppm, hardness 200ppm. Cyanuric acid at 0. What don't need to put in?
    Jun 2015
    Columbus Indiana
    6
    Re: High TC
    I re tested the alkalinity too. It is low. So do I take care of that first?
    May 2014
    Franklin, NC
    9,184
    Re: High TC
    If you have been using picks, you have CYA/stabilizer I the water. The test strips are just junk.
    You really need a reliable test kit. Here is what you want. TF100 Test Kit
    If you order it today you will have it mid week.
    I'll be honest, we don't like to give suggestions based on test strips. For now I would use Pool Math to figure how much Borax to add to bring the pH up to 7.2 and keep chlorine,in the water until your kit arrives.
    Support the site
    Jun 2015
    Columbus Indiana
    6
    Re: High TC
    Okay. Thank you. I have ordered the test kit. I will reply with the newly tested results when I receive the kit. Should I start a new thread then or just post a reply on here?
    May 2014
    Franklin, NC
    9,184
    Re: High TC
    Keep it all here. The OTO chlorine test you have is good to 5ppm and the pH test should work, so get the pH in line while you wait for the test kit.
    Support the site
    Jun 2015
    Columbus Indiana
    6
    Re: High TC
    Kit came in. I did all test but the calcium. The FC showed off charts still orange. CC - zero. Which I don't understand. PH 7.5. TA- 120 but it didn't turn red it turned yellow. And the CYA-80ppm. I've had the chlorine pumped turn off since I found the high chlorine.
