Thread: Salt water pool and shick
    Jun 2015
    Lake creek,tx
    1
    Do I still need to shock my pool regularly even when using a salt water system?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Salt water pool and shick
    Welcome to TFP.
    We at TFP do not shock our pools. We follow the process called SLAM if our pools go cloudy or green.
    Do you have a recommended test kit such as the TF100 or the K2006? If not it will be the best investment you ever made for your pool.
    Please read the ABC's of pool water chemistry and Recommended levels in pool school.
    As long as your pool is balanced you should not have to SLAM.
    SWG are designed to help maintain your FC. You will likely still have to add bleach to get to the target level for your CYA.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
