Thread: Skimmer Box ID and Help
    Mar 2015
    Upland, CA
    222
    This is the inside of my skimmer box. I have no idea what brand it is because I have found no identifying marks anywhere. My real frustration is that I'm trying to figure out how to get suction from the main drain, but as you can see the lever that presumably accomplishes this is broken. Any ideas?
    20k gal. IG plaster w/spa. 2 HP Aqua-Flo "A" pump, Hayward DE6020 filter. "The Pool Cleaner".
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Skimmer Box ID and Help
    Generally there are two openings in the bottom of the skimmer if the main drain is plumbed through it. I only see one. Is there a second skimmer somewhere? Any mystery valves near the pump?
    Mar 2015
    Upland, CA
    222
    One skimmer only. Unless buried in the yard somewhere there are no mysterious valves. There are only two three-ways at the pad - one for spa/pool suction and the other for spa/pool return.
    I know all the flow is currently from the skimmer because it accidentally sucked up a floating rubber toy once while the basket was out and when that stuck to the pipe the pressure dropped to zero at the filter. I thought maybe the main drain might be tied to the spa drain, but when I set to spa suction and spa return there is zero overflow from the spa. That lever that used to be at the bottom of the skimmer, and what appears to be some sort of scale on the right, have to have been for something.
