Thread: New to site and pool care
    Jun 2015
    Delta, oh
    2
    I have an 16x32 inground pool with a liner and a hayward pump and we have had pool for just a year. I live in Ohio and we had heavy rain all day and probably got over 6" of rain yesterday. In between downpours I turned pump on and put the port to waste and drained water out, just a couple inches and turned off pump. I wake up this morning to the water drained to the skimmer and started freaking out! Do you think because i left the port handle on waste, it could have drained? But the pump was not on at all. Thanks for any advice!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New to site and pool care
    Welcome to TFP!
    Yes, I think in that position if the pool is above the pump the water will slowly drain out the backwash pipe.
    Support the site
    Jun 2015
    Delta, oh
    2
    o no! even if the pump is off? thanks for replying so fast i appreciate it!
    May 2014
    Franklin, NC
    9,184
    In that setting the only thing holding the water back would be the pump impeller and it will move freely. Gravity does the work instead of the pump motor.
    Support the site
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP! Dittos on what Tim stated.
