Thread: CircuPool SJ-30 Polarity Problem
    Jun 2015
    Ocean Springs MS
    12
    Hi all. New to the forum.
    I have a new SJ-30 installed on my month old vinyl 16x32 15,700 gallon pool. I decided to switch from trichlor to SWG as we like the way the saltwater "feels". I dissolved 440lbs of salt and started the unit 24 hours later. Works fine on all settings but polarity 1 at 25%. After about a minute, the trouble light comes on and it stops generating. The pool store confirmed 3500ppm salt this morning. I added another bag to raise it to theoretical 3800 but still have the issue. Anyone have any clues? Thanks!
    Taylor K-2006 results
    FC 5.2
    CC 0
    PH 7.6
    TA 120
    CH 190
    CYA 35 (added 4lbs after test)
    Casey's Avatar
    SW PA
    10,453
    Re: CircuPool SJ-30 Polarity Problem
    Welcome.
    I'm not completely sure that I can address all of your problems with the SWG but I do know that you need to significantly raise your CYA up to at the minimum 70ppm to run the SWG.
    Also, if you could finish filling out your signature, it would be very helpful! What we need to know to answer your questions
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Who did the installation work, you or a pool builder? If a pool builder, call them to fix the problem. Also, purchase your own salt test kit, such as:
    TFTestkits.net .
    Are there any red or yellow warning lights lit?
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Jun 2015
    Ocean Springs MS
    12
    I did the installation work. Salt test kit is on the way . The only indications of a problem are a solid Service LED and no chlorine production when on polarity 1.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Polarity 1 & 2 are for the self-clean mode. I would call Circupool about it.
    Steve
    Jun 2015
    Ocean Springs MS
    12
    I contacted the manufacturer and they were very helpful. He confirmed that there may be a problem with then controller and they're sending a new one. In the mean time I've been running the unit periodically on super CL. I'm able to keep the balance as below. How does this look?
    FC 5
    CC 0
    pH 7.2
    CYA 80
    Salt 4100
