Thread: Too cold for SWG????
    Rockcrawler's Avatar
    El Paso, Texas
    174
    I was checking my pool numbers and noticed by FC has dropped down to 2ppm, about 3 months ago I shut the SWG off (first winter with the SWG) and threw two pucks in the floater (I'm only at 50 CYA). I usually do this every winter(add 2 pucks) so I dont have to mess with the pool, the pucks are gone and I went threw the Pool Pilot Manual about a minimum "safe" operating temp, I couldn't find one, my question is can I turn my SWG on with my water at 47? I run my pump about 2 hrs a day, I was thinking about putting the Digi on boost cycle to gets some clorine in the water?
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    Re: Too cold for SWG????
    I also turned off my SWG a couple of weeks ago and have been using bleach. Very easy. My manual says (if memory serves me right) that the SWG will turn itself off when the water temp. drops to 50 or below.
    - 25K Gallons, Jandy AquaPure Model Pure1400 SWG w/ AquaLink RS PDA, Jandy LXi Heater Model 400
    - Jandy CV460 Cartridge Filters
    - IG Plaster Pool w/ rock waterfall & weeping walls, Elevated spill-over spa
    - 2 X Jandy Stealth SHPM2.5 pumps (one for pool, one for waterfall), Pool Pump ~ 100 GPM in pool mode
    - UltraPure UPP25 Ozone Generator, Polaris 280 w/ Polaris Halcyon booster pump
    Different brands of SWGs deal with low temperatures differently. The Pool Pilot units will only run at 1% when the water is very cold. Some other brands turn off completely. In general, when the water is very cold, below 50 degrees, you need so little chlorine that it is simplest to just pour a little bleach in once every couple of weeks.
    Ft Lauderdale, Florida
    1,455
    Yes, you can press the boost button to override the temperature compensation and run a 24 hr boost mode. That should be more than enough to sustain a higher chlorine level for quite a while in the cooler temperatures.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    El Paso, Texas
    174
    Thanks for the info just wanted to make sure I wans'nt damaging the SWG will low temps.
    Jul 2007
    Brisbane, Australia
    874
    it does place more strain on the cell
    wouldn't damage it though
