Results 1 to 16 of 16
Thread: pool pump
    May 2015
    Moline, IL
    31
    pool pump
    whats the best kind of pool pump?
    Casey's Avatar
    SW PA
    10,444
    Re: pool pump
    Well, that's hard to answer without knowing what kind of pool you have.
    Please fill out your signature as outlined here: What we need to know to answer your questions
    May 2015
    Moline, IL
    31
    Re: pool pump
    i have a inground pool with about 32,000 gallons of water
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: pool pump
    Water features, spa, slide, in floor cleaning, filter type and size?
    Utility cost, any chance of a rebate program for two-speed or variable speed?
    chiefwej
    May 2015
    Moline, IL
    31
    Re: pool pump
    No water features, no spa, no in floor cleaning, sand filter, no rebate,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: pool pump
    If you want best, I'd say go with a variable speed pump. The Pentair Inteliflo 011018 3 hp pump might be a good choice.
    chiefwej
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: pool pump
    3hp is WAY overkill for a pool without a spa, fountain, etc. definitely go either two speed or variable, but without the extra features a 1.5 hp is probably fine.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: pool pump
    The Inteliflo 011018 has onboard controls that allow a lot of flexibility. Because it has 3 hp does not mean it cost a lot, or cost a lot to run. Mine spends most of its time running at 1000 rpm, using the electricity of one 100watt bulb, and you can buy the pump for about $800. I even got an extra $100 rebate from Pentair on mine. I think it's a good choice and a good value, but may be a bit prejudice based on my experience with mine. Your pool, your choice.
    chiefwej
    May 2015
    Moline, IL
    31
    Re: pool pump
    any others? how load is the 011018?
    rubone74's Avatar
    Jun 2015
    29
    Re: pool pump
    I have a Pentair intellipro as well. I like it because it is new and fancy with cool buttons to push. My pump runs at about 1100 rpm most of the time and the display shows it using about 120watts or so. I turn it up to about 2700rpm to run the infloor cleaning system for a few hours a day. The display shows it using about 1100watts at this speed. I've only had mine a couple of months but I am very happy thus far.
    13K gal, inground, pebble, 3HP Pentair Intellipro VS pump, Sta-Rite System 3 cartridge filter, A&A infloor cleaning system, Taylor K2006 test kit. Build date 06/15.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: pool pump
    I'm recommending a 3/4 hp 2-speed with a manual high/low switch and an intermatic mechanical timer. Run in low most of the time. It will be a pretty bullet proof setup.
    This Pump or comparable:
    Pentair SuperFlo Pump 341111. Pentair 341111.
    Then this timer: Intermatic T101R 120-Volt SPST 24 Hour Mechanical Time Switch with Outdoor Case - Wall Timer Switches - Amazon.com
    Or if you want to get fancy/automation: Amazon.com: Intermatic PE153 Digital Time Clock In Metal Enclosure: Home Improvement
    The PE153 will switch high/low speed for you.
    How much do you want to spend?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: pool pump
    The thing with a two speed is, by the time you add the cost of a controller to switch speeds, the cost is getting close to a VS pump with lots of versatility and a timer/controller built right in.
    chiefwej
    Apr 2011
    Murrieta, CA
    2,360
    Re: pool pump
    I haven't sipped the VS pump cool aid yet. There are places where they're called for (high electrical rates (greater than $.30 KwH, lots of water features) but in some places they don't add value. They don't recoup the additional cost in energy savings. There's no right or wrong, but it comes down to individual situation and preference.
    As a side note, will you be leaving the pump out side year round or bringing it in? Using unions will make it easier to remove and bring in, if you decide to go that route.
    May 2015
    Moline, IL
    31
    Re: pool pump
    how about hayward-pool pumps?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: pool pump
    I'm very happy with my Hayward VS pump, it's nice to be able to dial in just enough RPM's to run the heater when needed. You should check with your power company if they offer any rebates for VS pump's and for which models
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: pool pump
    I have the 011018 (it's in my sig) and VarSpd is the cat's meow, the bee's knees...amazing little pump with a TON of versatility. You can really dial in the exact amount of flow or pressure you want.
    It has its own timer.
    A tech at Pentair suggested I used pressure gauge on my filter to adjust the rpms of the motor. With my solar panels running, he said 15 psi should be plenty. That equated to 2500 rpm. In the winter with no solar running and the pool closed, he suggest 5 psi. That may not break a 1000 rpm. I have a flow meter on order so I'm curious to see the rpm vs. pressure vs. flow curves.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
