Results 1 to 7 of 7
Thread: Pool lost 6" of water
    DGS's Avatar
    Jun 2015
    memphis tn
    34
    From 6:30AM today until 9PM tonight the pool water level dropped 6"
    The day before it lost 4"
    The pool just finished a 3 day SLAM and looks great and is balanced and no one was in it until 7PM today.
    I am eliminating "splash out of water" as there were only 3 people in it and the activity was pretty limited for those 2 hours (7pm-9PM)
    Today was mainly overcast so it wasn't evaporation.
    It doesn't appear to be a leak at the equipment pad.
    I will do a bucket test but losing 4" and then 6" doesn't seem to warrant the test.
    I am at a loss.
    I can send photos in the morning of the equipment if you need to see what is what over there.
    Help!
    Thanks!
    Memphis TN New to owning a Pool.Appx. 25,000 gallon inground gunite outdoor pool appx 20x40 curvy shape surrounded by 10 large crepe myrtles and other trees.Pool was installed about 20 years ago.
    Triton II Sand Filter Pentair Chlorinator 3" tabs Polaris vacuum 3' to 7' with a diving board. Taylor 2006 FAS DPD Test Kit
    Casey's Avatar
    SW PA
    10,428
    Re: Pool lost 6" of water
    I would suggest to let the pool go until it stops leaking which can be at a few different points... the skimmer, a return, or the light niche if you have one.
    Is it wet near your pump set up? Do you have a main drain? Do you notice it leaking faster when the pump is on or off?
    DGS's Avatar
    Jun 2015
    memphis tn
    34
    Quote Originally Posted by Casey View Post
    Apologies but what does "let the pool go" mean?
    30,414
    It means let it leak down until it stops. That level will indicate where the leak is.
    I also agree there is absolutely no need to do a bucket test. With the loss you are describing, no further confirmation is needed.
    Casey's Avatar
    SW PA
    10,428
    Just let it leak out until it stops.
    DGS's Avatar
    Jun 2015
    memphis tn
    34
    The water loss stopped at the bottom of the skimmer level.
    Pool Expert came by and said it was a case of someone turning the multiport valve without turning off the power and/or not pressing down on handle when turning the multiport.
    This caused the rubber gasket thing inside the multiport to "roll and compact itself"which allowed water to enter the waste chamber when the multiport was set to filter. A spillover effect from one chamber to the next.
    Pool is no longer leaking.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Good news! Thanks for posting back with the solution.
