Results 1 to 10 of 10
Thread: OTO test kit help
    Shelby123's Avatar
    Jun 2015
    Timmins/Ontario/Canada
    16
    OTO test kit help
    Hello, hoping someone can help me out...I have a Waterpik Technologies test kit that tests chlorine and pH with OTO and the Phenol drops. Problem is I can't find the instructions for how many drops and can't seem to find it online anywhere. I've seen 5 drops a lot but my sample container is very small compared to other kits I've seen. Is there a ratio of OTO drops to water sample size? I'm trying to find a better test kit but my options are limited where I am and will need to order online, since I won't be using the pool store after finding this site!!! Was complaining to my neighbour i couldn't get alkalinity plus anywhere in town and then found this website and fixed the problem with baking soda
    Second year with the pool and have no significant issues that I could see....I would like to be able to more accurately test my chlorine levels properly (without going to the pool store for analysis and then feeling like I HAVE to buy what they recommend!) in case something is going on that I can't see.
    Would appreciate any help I can get with the OTO radio till I can get a better test kit
    16' round above ground intex simple set; 1000gph intex cartidge pump; Timmins, Ontario (8 hrs North of Toronto)
    38,290
    Re: OTO test kit help
    Welcome to the forum.
    Most all kits are 5 drops that I am aware of. But, actually it does not matter. You can use more or less drops and the color will be the same, although the saturation will be different. I know that is true for the pH and pretty sure it is true for the OTO.
    30,421
    +1 what jblizzle says.
    Shelby123's Avatar
    Jun 2015
    16
    Thanks so much!!!!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I don't understand. The OTO test is all about saturation, not color. Between 0.5 and 5 ppm the color is the same but saturation increases with higher chlorine level. I think the number of drops does matter.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    38,290
    I was speaking about the pH test, that was not clear.
    Jul 2016
    Canada
    1
    Quote Originally Posted by epro05 View Post
    I have the same issue - bought a house and this test kit was included with the hot tub, but no instructions, and searching for "Waterpik" online brings up dental accessories. I know the number of drops is directly relevant, would love to figure out how many are needed for this kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Shades of yellow are some of the hardest for the human eye to see, but with the OTO test like the pH test you are looking for color shift, you will note that at 5 ppm the OTO test will appear much more amber than it does at 2 or 3 ppm, and if you go even higher than the test block reads you will see school bus yellow, safety yellow, and eventually burnt orange.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    That is a Taylor K-1000. The instructions are here, Welcome to Taylor Technologies
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    I have the OTO test kit supplied with the TF-100.
    Tested the TC and the PH with 5 drops per instructions.
    Also tested with pool water level at the 1st mark and 1 drop and get the same results as with the 5 drops and the 5th + mark.
    This can save reagents but those are inexpensive and widely available so not worth doing that way as it is harder to see the color as it isn't aligned with the 1st mark.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
