Thread: Comm error or failure
    Mslc10's Avatar
    Jun 2015
    Bulverde, tx
    13
    Jandy/zodiac epump screen reads normal but when I try and turn on manually it goes thru it's steps but pump doesn't start and screen reads comm fail. It's dark now so it's powerd down. Any ideas? I haven't opened pump access pt yet.
    Casey's Avatar
    SW PA
    10,444
    Re: Comm error or failure
    I'm not sure but someone will be along to help you get this situated.
    I did however want to welcome you to TFP. Hope you enjoy the forum.
    Mslc10's Avatar
    Jun 2015
    Bulverde, tx
    13
    Thank you! Upon morning coming have disassemble pump and control has water in it . Seal doesn't seal very well! It's cooroded inside. Trying to clean it up and dry it out.
    Mslc10's Avatar
    Jun 2015
    Bulverde, tx
    13
    Update was replaced under warranty.
    about a year later new pump would try to start up but then something would drag and slow the pump . Took motor apart to find magnet came unglued from armature. Ordered one off eBay but then called pool guys. They would come out to replace motor but it would be a few days . Pool was turning green so I JB welded the magnet back in place and let sit overnight. Put back together and pump is still running to this day. Guy came to change it I told him that unit is running because I glued it back. He said " I'll leave you this new one if I can just get the tag off the old one ". I said sure ! So I actually have two complete motors and speed controls ( one I bought off eBay before I knew they would replace it under warranty) plus the one that I fixed that is still whirring away...
