Thread: Kaye
    Jun 2015
    Corpus Christi, Texas
    1
    Kaye
    I have a sand filter and copper ionization. Trying to empty sand out of filter. Most of it has turned in to hard copper/sand crust around entire inside of filter. Very hard to remove without breaking something. Anything that will dissolve this?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Kaye
    Yuck! I don't know.
    Here is a tutorial on deep cleaning a sand filter, pics and all!
    Deep Cleaning a Sand Filter
    Casey's Avatar
    SW PA
    10,423
    Re: Kaye
    I don't know Kaye but once you get it cleaned up, get rid of the copper. It's only going to cause you more grief.
    Welcome to TFP.
    22,542
    Re: Kaye
    It's possible that you have calcium scaling. You could take some dilute muriatic acid and pour in it and if it fizzes up it may break it up enough to get it out.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Kaye
    Welcome to TFP! Another plug for getting rid of the copper - all it will do is add metals to the water and turn blonde hair green. Chlorine, and chlorine alone, is all that's needed for proper water sanitation.
