Results 1 to 15 of 15
Thread: CC Help!
    May 2014
    Oklahoma City
    56
    CC Help!
    Ok I did a Jacks Magic treatment in late April/May. It says you will get false FC readings for about a month. Well I've reached that point. I've been seeing high CC levels and decided to SLAM the pool today.
    Levels before:
    FC- .5
    CC - 8
    pH - 7.8
    TA - 120
    Cya - 50
    I raised my FC up to slam level and just checked it after 2 hours. FC is 22, but CC is 21 now. Is this normal? Pool is perfectly clear.
    25,000 gallon Gunite in ground pool built in 2010. Hayward Tristar 1hp pump, Hayward Smartfilter 550 cartridge filter with 4 Pleatco PA-137 filters(replaced 2014), Nature 2 Fusion in ground(only used for when out of town now that I've switched to bleach), and a Polaris PB4-60Q booster pump.
    Casey's Avatar
    SW PA
    10,461
    Re: CC Help!
    Do you have ammonia in the pool? Maybe you should check for it.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    How do you check for ammonia?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: CC Help!
    There are aquarium tests you can use, but in the end, if your CC is that high, you need to SLAM it.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    I'm doing a SLAM now. Just checked again after another hour and a half. FC dropped to 17 and CC raised to 25. Im at a loss as to why CC is climbing. Shouldn't it be dropping? I added more bleach to bring to shock level.
    Casey's Avatar
    SW PA
    10,461
    Re: CC Help!
    It could be ammonia.
    Go to a fish store and buy an ammonia test and see if that's what it is. When CC is that high, it's usually ammonia and you'll need a lot of bleach to get rid of it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: CC Help!
    Yes, you will need to test and add bleach/chlorine every couple of hours at first.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    This morning I have a FC of 8 and a CC of 35. I'm going to go buy an ammonia test, but does anyone know if it causes your cc to rise like this when you shock? I've gone from a cc of 8 to 35 by shocking.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    Ammonia test came back 0. I checked it 3 times from three locations. Is it possible I'm still getting false readings from the jacks magic treatment?
    The treatment said you get false FC readings for up to a month so to use TC readings. I started the treatment at the end of April.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    Anyone have any thoughts? Should I keep shocking? I stopped yesterday, but an email from Jack's Magic made me 2nd guess. He said you could actually raise CC if you don't hit a high enough shock level. Thoughts??
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Re: CC Help!
    Quote Originally Posted by Thump4863 View Post
    Those are some crazy CC #'s! Are you positive you are not confused with TC somehow?
    Which test kit are you using to get these readings?
    Edit: Did you ask Jack's Magic how high you would need your FC to break this cycle?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    In using a Taylor K2006 FAS DPD test. I'm positive that I'm doing it right and not getting it confused. One Big Dipper and add regent for FC. Add 5 drops of the other and then drops to calculate CC.
    I didn't ask Jacks that. He just said my numbers seemed legit and there didn't sound like a false reading that they normally get.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CC Help!
    If you didn't experience an unusual CYA drop, and usually that also would require the FC to get to near zero at some point, then I don't think this is ammonia. Also, with ammonia, you would not be able to hold FC at all -- it would go away in less than 10 minutes (within a minute or two) after adding chlorine. Instead, this sounds like test interference from the Jack's Magic in spite of their saying it's not like the false reading they normally get. Did you let Jack's know that you were significantly elevating the chlorine level? They usually deal with people keeping the FC at 10 ppm or less.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    CYA hasn't dropped since I added it for the season, and has been a constant 50. I talked myself into thinking it was the false reading and to go with TC. Yesterday after full sun both numbers dropped significantly together but CC is still the high number. There is no smell, pool is crystal clear, and ammonia test came back as zero. I just don't want to think its ok and kill my kids by swimming in something they may not need to!
    Edit: Yes I did tell him how much I added. I gave home 4 or 5 different readings as well.
    May 2014
    Oklahoma City
    56
    Re: CC Help!
    Another sunny day. FC dropped to 1 and CC dropped to 24. That's 25 TC.
