Thread: light not working, transformer maybe?
    Jun 2015
    st petersburg fl.
    2
    I will describe this the best as I can, I was fixing the small leaks in the skimmer today and noticed that the cover for the light looked bad. So when i finally got the got the fixture removed I noticed the cover was cracked but not leaking. I bought a new cover and gasket. I noticed the light bulb was hanging inside so I figured I would replace it too. I put a new light bulb in and reinstalled the fixture then went to turn on the light, all that happens now is the transformer is buzzing and the light will not go on. Any suggestions would be very helpful, Thank you in advance!
    Casey's Avatar
    SW PA
    10,461
    Re: light not working, transformer maybe?
    Hopefully someone will be along shortly to help you. In the mean time, keep the light off.
    Welcome to TFP!
