Thread: Liquid Chlorine
    Jun 2015
    Wamego/KS
    120
    I was at Menards and they had liquid chlorine (12.5%) on sale for $1.97. I bought some but then started wondering if there are any ingredients I should avoid putting in the pool?? Should I only be looking at the 12.5% sodium hypochloride or do I also need to pay attention to the other ingredients?
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Donldson's Avatar
    NW Ohio
    2,916
    Re: Liquid Chlorine
    Nope, the stuff they are selling there is good and when they have it on sale at that price it is a good buy! It will degrade fairly quickly so if you stock up make sure you don't get more than you will use in the next few weeks unless you can store it in a cool dark place.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Liquid Chlorine
    I doubt there are any other additives to worry about. It should be sodium hypochlorite and a little sodium hydroxide (lye). That's it.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
