Results 1 to 10 of 10
Thread: Stainless Weber Gas Grill Spots
    Jun 2015
    Austin, TX
    1
    I have a stainless steel Weber Genesis gas grill. I owned it for 2 years at a prior house that does not have a pool and it looked great. Now that the Polaris sprays it occasionally, it has spots. It is not like a rust because it is still smooth. It looks like corrosion of some sort. Does anyone know how I can clean this off?
    16,800 Gallons, In Ground, Plaster, Triton II Sand Filter, Century 2.5 HP, Polaris, Liquid CL
    Jun 2015
    Blue Bell, PA
    7
    Re: Stainless Weber Gas Grill Spots
    You can try some very fine steel wool and rub with it gently. Typically referred to as 000 or 0000 steel wool and sold in the paint isle in Home Depot or Lowes. Just go in the same direction as the brushed metal finish.
    30k gallon, replastered (June '15), 1.5hp Hayward Super Pump, Hayward 60 sq ft DE filter, Hayward chlorinator, Rheem 406k heater.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Welcome to TFP!
    We probably have the same grill and I know what you are talking about. This is a before and after on my doors. I use Bar Keeper's Friend Soft Cleanser. Target, Lowes or Home Depot have it.
    https://www.barkeepersfriend.com/cle...soft-cleanser/
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Don't use steel wool, it has a finish that steel wool will damage. I can sympathize with the stains because I also have them and I keep mine covered most of the time. I just gave up trying to clean them. It still cooks great.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    After you get the spots removed and to protect new one's from forming, I would apply a thin film of oil-based stainless steel cleaner. I, along with several of my friends, use this one from Sam's: Sprayway® Stainless Steel Cleaner - 2/15oz can - Sam's Club.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Try Bar Keeper's Friend if the milder stuff doesn't work.
    May 2015
    Sand Springs, OK
    13
    After bar keepers friend, I use a lite cover of baby oil. Works great. Indoor saltwater pool.
    Oct 2012
    604
    Thanks for the tips about Bar Keepers Friend everyone. I am going to try it on mine.
    Mar 2015
    Rochester
    41
    Quote Originally Posted by ComputerGuyInNOLA View Post
    How did it work?
    24' Round AGP
    Oct 2012
    604
    Scaboney,
    My wife happened to have some Bar Keepers Friend under the sink. I cleaned it two weeks ago and it worked great. Now my grill looks new again. Great stuff.
    Dave
