Thread: Coloring rock wall mortar
    robbief00's Avatar
    Dec 2014
    TX
    40
    Does anybody have a recommendation for the best way to color the existing mortar on my moss rock wall? It has always been lighter than the rocks and the sun seems to have whitened it even more. I prefer the joints to be more brown to blend in with the rocks.
    I know you can buy colors to mix in while setting the mortar but I'm not sure what can be used to coat/paint the surface after it is cured.
    Thanks!
    My Pool Build
    15k gal IG freeform w/ attached spa, Wet Edge Luna Quartz Bermuda, 3.5' to 5.5' depth, Intelliflo VS pump, Cartridge filter, MasterTemp heater
    1 hp Whisperflo for ledge bubblers/weeping rock wall, Polaris 280, EasyTouch 8 Automation, Intellibrite 5G color LED's, TF-100 w/ Speedstir, Stenner Peristaltic Pump
    38,489
    Re: Coloring rock wall mortar
    I would think air brush painting, like they do for fake rock waterfalls.
    Feb 2014
    Upstate, NY
    390
    They sell colored additive for cement/grout. Home Depot sells it in the cement section.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    38,489
    Quote Originally Posted by Donny View Post
    A little late for that in this case ... as the OP stated
    I suppose you could try to put another colored layer on.
