Thread: Pentair IntellifloVS Pump with Error Messages- DISPLAY Not Active
    Jun 2015
    orlando fl
    1
    I have a recently installed Pentair Intelliflo VS pump that keeps giving my the same error message over and over. "DISPLAY Not Active!" I get the message as I'm trying to make adjustments to the speed or really making any changes. It will popup in the middle of making a change and I'll have to start over.
    Very Frustrating. Is this normal or a defect?
    Thanks
    Jan 2012
    340
    Re: Pentair IntellifloVS Pump with Error Messages- DISPLAY Not Active
    Sounds like you are hooked into automation. If so, speed are adjusted within your programming.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP
    Yes, when the pump data cable is connected to automation then the display/control is disabled on the pump and you need to change pump settings from within the automation menus. Easytouch, Solartouch, etc.
