Thread: Need help Decorating above ground pools
    Jun 2015
    Beaufort, SC
    1
    Question Need help Decorating above ground pools
    We just recently had our in ground pool buried and bound an above ground pool. I need help with decorating this eye sore. Any in expense ideas would be appreciated.
    Decorating 17 x 5 foot above ground pool.
    Casey's Avatar
    SW PA
    10,450
    Re: Need help Decorating above ground pools
    How about some pics?
    Welcome to TFP!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    How about making a garden all around the pool?
    3 ft wide all around and plant some caladiums, of all colors, maybe a banana tree or two? If it gets a good bit of shade, hosta are great., as is some of the smaller varieties of fountain grass in the sunny areas. Im partial to fireworks fountain grass myself. Also throw in a bunch of Vincas of different colors. They are reasonably cheap and provde great colors.
    To keep grass from growing into the garden, make yourself a 4 x 4 inch trench all around at the outside edge of the garden. Grass will grow right up to it, but not encroach.
    then fill the garden with 3 inches of mulch.
    EDIT:
    Oh, and dont forget the obligatory Sego Palm!
    Divin Dave,
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    I've got to ask-Why'd you bury the in-ground pool?
