Page 1 of 4 1234 LastLast
Results 1 to 20 of 67
Thread: My SLAM
    May 2015
    Juno Beach , Florida
    210
    My SLAM
    So last night, I dropped from FC 6 to 1ppm at 10am this morning. Cannot delay the SLAM any longer.
    Wanted to keep a record here to make sure experts can help me do it right:
    6/27/15
    10am
    FC 1
    CC 0
    PH 7.2
    CH 450
    CYA 65/70
    10.20am
    Added 363 oz publix brand bleach
    1100 am
    FC 23
    CC 00
    11.10
    Added 90oz bleach
    As a side note, as I have never been sure of pool size, can I use this as a way of accurately calculating pool size as xxx of CL with raise xxx of water by xxx? So if I went from 1ppm to 23 ppm with 363 oz of 8% bleach, does that not equate to 11,000 gallons , instead of the 12,000 I have been working to thus far in my pool journey?
    thx
    12k SWG pool, free form. 1HP flotec pump, P90 Leslie's filter. Florida. Taylor 2006 test kit. I think plaster, waiting verification from here.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: My SLAM
    Unfortunately, bleach strength can vary a lot regardless of what the label says. Sometimes it's overstrength to allow for losses in storage. Sometimes it hasn't been stored well and for too long and it's weak. So it won't be accurate. However... if you're constantly overshooting, then the pol is probably smaller than you think and you should reduce the volume in poolmath. If you're constantly undershooting then it's bigger than you think and you should increase the volume in poolmath.
    Once the SLAM is done and you have a few weeks of normal maintenance, you'll be better able to finetune it based on FC additions and pH adjustments and TA drop.
    May 2015
    210
    Re: My SLAM
    27/6/15
    11.40am
    FC 29.5
    CC 0
    May 2015
    210
    Re: My SLAM
    27/6/15
    2pm
    FC 28
    CC 0
    For you experienced people, are these initial findings showing anything. I presume a 1.5 drop in 2.5 hours in sunlight is not too bad? CC is still zero and water is still perfectly clear.
    Should I add bleach to get it back up to 29.5 or leave it at the 28 mark seeing as that is 3 ppm over chart recommendation anyway? thx
    Jun 2014
    15,096
    Re: My SLAM
    If you are still actively SLAMming, then yes, keep it at your SLAM FC level until you are sure you've passed all 3 SLAM criteria:
    1. Water is clear
    2. You do not lose any more than 1ppm of FC overnight (that's the OCLT)
    3. CC (Combined Chlorine) is <.5
    So it looks like you still need to keep going until you pass the overnight portion.
    As for how much loss during the day is acceptable, that might vary based on a variety of factors. At your rate noted above, after 8 hours you might lose 4.5 ppm. With a CYA as high as your was listed (60/70) it looks like your bleach might still be fighting a few more organic materials ... along with the FL sunshine. Stay with it today and see how your overnight test (drop) comes-out.
    Looks like you are very close!
    May 2015
    210
    Re: My SLAM
    Is it ok for the kids to go swimming for a couple of hours between tests? thx
    38,275
    Re: My SLAM
    Not if the FC is above shock level.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: My SLAM
    As long as you can see the bottom, and the FC is below slam level, then its safe to swim in it.
    Divin Dave,
    May 2015
    210
    Re: My SLAM
    ok, thanks. Shock level is a bit abstract as it is based on CYA and that test is VERY inaccurate. So CYA is 65-75 , so shock level is 24 to 30 and I am tracking mid range of those at about 27. So, in my specific case, can I let them swim, thx ?
    May 2015
    210
    Re: My SLAM
    6/27/15
    3.50pm
    FC 24
    CC 0
    PH 7.4
    So now at the lowest end of safe , so will let them go swimming for hour or so. I will then add bleach and bump it a bit to 28, to take it to the high end of the possible range. That makes sense, right?
    thanks for ongoing help.
    Will make support payment later.
    cheers
    May 2015
    210
    Re: My SLAM
    4.15
    added 68oz bleach.
    Jun 2014
    15,096
    Re: My SLAM
    Doing well. Keep it up. Maintaining is the most frustrating part and it's easy to get impatient. Especially in the summer when everyone wants to swim. Post an overnight loss test in the morning to see if you held your FC overnight.
    May 2015
    210
    Re: My SLAM
    Will do , thx.
    With the overnight, do you test before direct sunlight ( 9.15 am for me) or at sunrise ( 6.25 am) . At I did it about 7.30 an last time and there was reflective sunlight on pool but not direct . Thx
    38,275
    Re: My SLAM
    Certainly before the sun hits the pool, the earlier the better.
    May 2015
    210
    Re: My SLAM
    6/27/15
    7pm
    FC 28
    CC under .5
    Will be dark in about 1.5 hours so will start OCLT at 8.30 pm.
    May 2015
    210
    Re: My SLAM
    6/27/15
    8.40 pm
    FC - 26.5
    CC - 0
    Should I leave that reading for my night test, or raise FC to 28 first?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: My SLAM
    That level is fine.
    May 2015
    210
    Re: My SLAM
    Ah, made a command decision so I get to forget it all until 6am alarm. Added 26 oz bleach . Will do last test in 30 mins.
    I lost 1.5 ppm between 7pm and 8.40pm, so I am guessing I will lose about 4 ppm with no sun overnight. Be interesting to see how close I am with guess.
    May 2015
    210
    Re: My SLAM
    6/27/15
    9.30 pm
    FC 33
    CC 0
    Really odd how pool calc said raising 26.5 to 28 was 26 oz of 8% for 11k gallon pool.
    Yet it went up to 33 , any ideas why such a massive discrepancy ?
    If you work it the other way round on the calculator, it should take 111oz to raise 26.5 to 33. Very odd , eh ?
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,438
    Re: My SLAM
    Make sure you're up and pool side before the sun comes up.
