Results 1 to 16 of 16
Thread: How high can my cya be?!
    Jun 2015
    Sacramento
    8
    Unhappy How high can my cya be?!
    Hey all
    new to this site and for the last 5 years I've been dumping Diclor in my pool. Well, this year I haven't been able to get it under control. I wonder why? Lol . Any way i got my test kit, recommended here and tested water . It was literally off the charts. No problem, I thought, I knew it would be high
    ive been doing a countinious water change for the last 48 hours at a rate of 4gpm.i can't see any change in my test results. Was my cya at 1000?!
    Btw my pool is 22500 gallons as calculated
    Help!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: How high can my cya be?!
    It very well could have been at 1000. We keep our pools "open" year-round here. Read the blue text
    Organic Contaminants
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Keep going! We've seen some high CYA for sure. 400, 600, 800, sooner or later it will get into range.
    Jun 2015
    Sacramento
    8
    Thanks
    i assume that since my test kit says to use 7ml of pool water and 7ml of test fluid I can use equal amounts of water and fluids in any equal proportion? Otherwise my test fluid will be gone before I reach proper levels!
    DFW, TX
    24,497
    Don't know about using less water and less chemical.
    But, you can do the diluted test to extend your test range to 200. Read post number 8 in this thread:
    Extended Test Kit Directions
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    hi mayjong, if you know its above 100, you only need enough enough volume of liquid to reach the 100 mark. theres no use using enough volume to fill the vial to 20 if you cant see the dot at 100
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Jun 2011
    Long Beach, CA
    2,789
    Sounds like you need a CYA test refill, TFTestkits.net. You can also do a search to see if anyone has it near you.
    Jun 2015
    Sacramento
    8
    Thanks to all
    still running a continuous water change. About 4 gallons per hour. Finally seeing some movement in my tests. At this point I figured cya was in the high 100s. Maybe even more. I think I have about another 48 hours of pumping and filling.
    So- when done what is the next parameter to attack?
    thanks!
    Btw- when all done I figure I will have done an almost complete water change
    domct203's Avatar
    Jun 2015
    CT
    3,589
    With all that water exchange I would think there is no way you have adequate chlorine in that pool, and that needs to be addressed.
    I'm assuming you stopped using the Dichlor 3 days ago, how have you been maintaining FC, and what is the current FC & CC level.
    You will most likely need to SLAM the pool to kill off any algae that has started to bloom.
    http://www.troublefreepool.com/conte...tain-shockingl
    Before you do anything post a full set of test results (FC, CC, pH, CYA, CH & TA).
    Please add all your pool details to your signature so we can accurately help you.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    DFW, TX
    24,497
    +1 on Dom's question about maintaining FC. Chlorine must be maintained above the minimum at all times based on the Chlorine CYA Chart
    Jun 2015
    Sacramento
    8
    Okay
    fc 7
    cc 0
    ph 7.2
    ta 120
    ch 210
    cya 90-100
    looks like my ph is a bit low and the obvious cya issue. Otherwise looks ok?
    i'll add a bit of chlorine and keep water changing. Water is crystal clear.
    22500gallon plaster pool, white bottom
    hayward 1.5hp pump,Hayward swim clear cartridge filter.
    DFW, TX
    24,497
    FC is too low. Minimum is the number it should never drop below, ever. Target is what it should be all of the time. Chlorine CYA Chart
    Jun 2015
    Sacramento
    8
    Understood. I added3/4 gallons chlorine. At this point, I'm going to wait a few days and see where cya settles. Plus I'm waiting for the cya test regent I ordered!
    Any suggestions on a dairy chlorine dose for my size pool? Is there a rule of thumb
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    You can use PoolMath to determine your FC range for your pool. Enter current test results in the "now" column, desired result in the "target" column and hit calculate. Be sure to complete details for pool size and type at the bottom of the poolmath page. This will also be where you see your FC range.
    Love TFP? Become a
    TFP Supporter!
    DFW, TX
    24,497
    Quote Originally Posted by Mayjong View Post
    2-4ppm is a standard range of daily chlorine consumption.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Every pool is different and sun, high heat, bathers, and organic material will all cause fc to drop. Some days I lose 1 ppm some I lose 4, just depends on what's happening that day. After using liquid chlorine for a while you'll get a feel for your pools needs and can probably guess what to put in. Stay at target not the minimum, as long as you're below shock level it's safe to swim.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
