Thread: Repair Windows XP
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Repair Windows XP
    I have Windows XP install files on my Drive D. Is there a way to reinstall XP from here without reformatting and losing all my info and settings?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Repair Windows XP
    You can use the Windows transfer files and settings application.
    http://www.microsoft.com/windowsxp/usin ... ber12.mspx
    This application will backup your files and settings which then can be restored after windows is reinstalled. Make sure to save the backup on the D: drive or an external drive.
    You will still wipe out the C drive but then you can restore your settings and files. You will need to re-install the other applications but some of those settings may also be restored.
    Mark
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, I'll remember that for future reference. I just got thru reinstalling XP and all my files that I did back up. I lost a few things but the important things are still there.
