Results 1 to 12 of 12
Thread: Which Stabilizer is best?
    Jun 2015
    Arlington, WA
    5
    Hello again, I believe I fixed my signature so it should now show my info! I have won the battle with my levels...I believe. ..now I just need to add some stabilizer, the pool calculator let me know this! That site is amazing by the way and so is this one....Thank you for helping this new pool owner learn about the best ways to maintain my pool! I am heading to Walmart today to pick up some stabilizer but I don't know which one is best...any suggestions for this newbie?
    15'x36", 3300gal, AG, RX600 Filter System, RX600 Pump type, using a hth 6-way test kit.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Which Stabilizer is best?
    You can get the HTH brand with the purple cap.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I think they only have one. I have seen the Clorox brand and the My Salt Pool brand at different stores.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    As long as the label shows it as 99 or 100% Cyanuric acid, it's the right stuff.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi MissLaci,
    Walmart carries the HTH brand of Stabilizer & Conditioner - granular type. Thats what I use. It comes in a 4 lb jug.
    If not seen any other brand of stabilizer that they carry (at least not in my store).
    If you look at the ingredients on the jug, it should say 95 % or higher, cyanauric acid.
    There are liquid ones too, but they are expensive and not a good value vs the granular.
    Hope this helps,
    Divin Dave,
    May 2014
    Franklin, NC
    9,184
    That is weird. I would think WalMart would only have one supplier but looking at responses they must do things differently regionally.
    Support the site
    Jun 2015
    Arlington, WA
    5
    Thanks guys! I will let you know which one I get and then I will post the results. I should have started with my cya but I didn't and let's just say I have been having a hard time keeping my fc up in the right range!
    Apr 2015
    Quinlan, tx
    811
    But you learned something new! The stabilizer does really help and I get mine from wal-mart too.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Walmart used to carry the HTH brand. They now carry Clorox. Some still have HTH stuff from the last few years so they're selling that first.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    I know this is an old thread, but for some reason my local stores have stopped carrying a good number of HTH products. I used those in previous years (mainly the sanitizer, and alkalinity increaser) with pretty good results. Building on that which is noted above, I do see a Clorox product that is available locally (Clorox Pool and Spa Chlorine Stabilizer) that is 100% Cyanuric Acid. I believe this to be correct based on my reading above and if others run through the same issue I have, perhaps resurrecting this thread will save them a bit of time.
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, it is fine. Any 100% cyanuric acid product is fine. Clorox bought the HTH brand. Avoid all Clorox products labeled with Blue, those contain copper and will stain your pool, dog, hair and fingernails.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    And don't buy "Alkalinity Increaser" pool product- Just go to Walmart and get the large bag of baking soda from the baking aisle. It is the very same ingredient but much, much cheaper.
    Maddie
