Thread: What is the likely putty on this light wire/housing interface?
    The power supply to my light shows no damage but the plastic that abuts the housing certainly doesn't look water tight.
    How To Install an LED Pool Light Bulb - YouTube
    Is this putty a good idea? Look at Time = 1:00.
    Thanks!
    Bob
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    Casey's Avatar
    SW PA
    10,444
    Re: What is the likely putty on this light wire/housing interface?
    I don't have a light in my pool so I can't honestly answer but someone who knows will be along to help you.
    Apr 2013
    Sacramento, CA
    2,769
    The putty on the light housing in the video is factory installed. You should not use putty on a light housing to seal it. They are not field reparable. If it leaks the light housing (or the entire light) should be replaced.
    Jun 2015
    Wildomar, California
    423
    Actually, I've repaired/replaced over 200 lights in my career and have never seen a new light with epoxy putty on it. Also, you would NEVER do a pol light repair without replacing the lense gasket. That video was not correct as to procedure. Any light that I have opened with moisture in it Would be replaced.
    Jan 2012
    340
    I will second that the epoxy in the video is not factory installed. If your fixture is leaking from the cord, best bet is to replace.
