Thread: Planning Cement Block Pool Build
    Jun 2015
    Hayes, VA
    2
    New to the forum and I have read many threads and can't quite get the question(s) I need answered. I am interested in building a cement block pool with slab bottom, as I would like to tile the entire pool. I am a contractor and have a thorough knowledge of block filled with concrete and rebar construction/design. My question(s) is in regards to the process after the block is installed. Should I waterproof the block and then plaster it, or should it by plastered and then waterproofed? It is my intent to use hydroban from laticrete for waterproofing unless advised otherwise. Also does the slab need to be plastered (i assume yes but not 100%)? Thanks for any advice you can provide as I'm sure there will be more questions to follow.
    Scott
    Re: Planning Cement Block Pool Build
    Probably better to ask this in the "Under Construction" subforum. Perhaps one of the mods will move it.
    I don't know the answer to your question, but my understanding was that the plaster does the waterproofing. I could be wrong. Experts in the Under Construction area should be far more helpful.
    Be sure to make electrical bonding a high priority. All the rebar, and all the ladders, light niches, and a grid extending at least 3 feet beyond the edge of the pool, should be electrically bonded. http://www.riverpoolsandspas.com/blog/bid/34682/Pool-Bonding-101-Why-Handrails-Coping-and-Water-Could-Shock-You Beyond the issue of electrocution, even tiny electric gradients in pool water can affect the inner ear, and make you lose your sense of up and down when swimming under water.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
