Results 1 to 13 of 13
Thread: Leveling the ground (tarp?)
    Jun 2015
    cape cod, ma
    23
    We decided to dig down a good 6" and remove all the grass and then fill with sand. It looks good and we are almost done with final leveling.
    My question is - do you put a tarp over the sand? Or just put the pool right on the leveled sand?
    Please keep in mind this pool is small (13x39) and only staying up for 2 months.
    Intex 13" x 39"
    upgrade to Intex 1,000 GPH pump
    upgrade to Intex small 7,000 Gallon saltwater system
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Leveling the ground (tarp?)
    I recommend putting a tarp over the sand. It helps protect the bottom of the pool better than just having sand.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Casey's Avatar
    SW PA
    10,448
    I've seen everyone use the tarp.
    Jul 2014
    Oakbank, Canada
    389
    Tarp.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2015
    cape cod, ma
    23
    Quote Originally Posted by DarrelB View Post
    Tarp.
    Can anyone tell me why we should use it?
    Intex 13" x 39"
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    It protects the bottom of the liner better than just having sand there. It can prevent grass from coming through the sand and growing into the liner as well as keep any small critters who dig underground and up to the bottom of pool.
    Lisa
    May 2012
    Las Vegas, NV
    92
    I cant seem to find a tarp for a round 22', any recommendation the one that came is bad quality.
    Can you tape 2 tarps together and cut it to size? its the only way i can think of doing it from buying from a local store
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by latin_racer View Post
    We usually buy tarps at Home Depot. Yes you can tape them together.
    Lisa
    May 2012
    Las Vegas, NV
    92
    Quote Originally Posted by Azgirl71 View Post
    thank you, any type is ok or do you know a better one?
    K-2006 TEST KIT
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I prefer the thicker ones. We have gophers and Bermuda grass that like to try to get through. Our first AGP gophers did make it through.
    Lisa
    Jun 2015
    cape cod, ma
    23
    Thanks for the info!
    Intex 13" x 39"
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome
    Lisa
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Do you have an Ollie's nearby? They carry a large variety of tarps at a good price.
