Results 1 to 9 of 9
Thread: Pump Selection on Owner/Builder
    May 2015
    keller
    129
    I am working out the detail on my build scheduled to start in approximately 3 weeks. I would like your help selecting the most efficient pump. I plan to have three 3ft sheer descents on the back walls along with three color cascade bubblers on the sun shelf. The water features alone will require about 160 GPM to properly function. I do not think that one intelliflo 3hp VS pump will be efficient to circulate the pool and run the features all at once. My plans are available in the Dropbox link (I could not figure out how to attach the PDF).
    My electric costs are about 10 cents/kwh
    Dropbox - Krukiel Oasis.zip
    Owner Builder; Under construction, 17K Gallons SWG IG Geometric; 31X20'; 600sf; 104ft perim; depth 4'-6'. Sun-shelf; bubblers; sheer descents; Dolphin M400; Pentair Intelliflo XF; Clean and Clear 520; Easytouch 8; IC40; 2 color LEDs; TF-100, K-1766, SpeedStir
    Jan 2012
    340
    Re: Pump Selection on Owner/Builder
    Have you though about an automation system to divert flow to your water features by themselves and not circulate the pool?
    The next step up would be an Intelliflo XF, but not sure how much flow that would provide. I don't have much experience with the XF pumps.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    May 2015
    keller
    129
    I am considering an automation system. IF I do most likely the easytouch with the built in screen logic.
    Would it be OK to NOT circulate the pool when features are running? Assuming that this would only happen while swimming.
    Jan 2012
    340
    Short periods would be fine. Plus, if you have kids, they're probably doing more for you than your return jets.
    You may find that you don't have to shut returns off completely to run water features, just turned way down.
    May 2015
    keller
    129
    good point - that infelliflo XF does look like a monster. A good bit more flow and the intelliflo
    Jan 2012
    340
    Just make sure you size your plumbing correctly if you go with XF. You won't get optimum results unless you're feeding that beast with 2.5" or 3" pipe. Also would be a good idea to use the new hi flow 3 way valves Pentair is making.
    May 2015
    keller
    129
    10-4
    May 2015
    keller
    129
    oops
    Jan 2012
    340
    3 phase power is uncommon in a residential setting
