Thread: I think I fried my Goldline Valve Actuator (GVA-24) for my solar heater
    Aug 2009
    Central PA
    64
    Tonight I just discovered that somehow the wire from one of the temperature sensors got wrapped around the handle of the valve actuator. As the actuator opened & closed over time (moving the handle each time), the wire got wrapped tighter & tighter until I guess it stalled the motor, leaving the valve partially open, and the 2A fuse inside the Goldline solar controller blown.
    I unwrapped the wire and replaced the fuse. The controller lights came back on, but the valve actuator did not move to complete it's cycle. When I played with the toggle switch on the actuator, the fuse in the controller blew again. I opened up the actuator - smelled a lot like cooked electronics. One of the capacitor(?) wires promptly fell out of the end of the capacitor.
    So... wondering where I go from here. Can anybody help me troubleshoot this? Is there any way to test to see if the motor is fried before I go to more trouble here?
    Any advice greatly appreciated!
    Steve
    29,000 gal. vinyl in-ground mountain lake (freeform); Hayward DE filter, 2 skimmers, AutoPilot SWG, 2 - 4 X 20 Fafco Solar Bears with Goldline control, Aquabot, LoopLoc winter cover, Pool installed March 2009...
    Casey's Avatar
    SW PA
    10,444
    Re: I think I fried my Goldline Valve Actuator (GVA-24) for my solar heater
    Steve, I can't help but someone should be able to here shortly.
    Jun 2015
    Wildomar, California
    423
    Its probably dead. Been there, had that happen. Handle got jammed and the motor burned up. It's only 24v and not able to take a lot of resistance. Sorry, sounds like such a fluke thing.
