Thread: setting up sand filter pump and salt water system
    Jun 2015
    Odessa,TX
    5
    A friend gave us a Krystal Clear Saltwater System (model CS8110) and Sand Filter Pump (model SF10110) to use with our Intex 22ft, 52 inch pool. We are unsure how to put together. Can these even be used TOGETHER at the same time? Any advice. THANKS!
    Intex above ground---22 ft. x 52 in.---10,400 gallon with Sand Filter and Salt Water System
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: setting up sand filter pump and salt water system
    This pic shows how mine are set up. Not sure if it will help or not.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    Absolutely. That's pretty much my exact setup.
    Go from the strainer in the pool to the pump first, then from the pump to the SWG, then back to the return in the pool.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP! Congrats on the new stuff!
    Intex has manuals and videos on their website.
    Here is the page for the swg
    120v Krystal Clear Saltwater System Cg-28663 - Intex
    and the filter
    12 in Krystal Clearâ„¢ Sand Filter Pump w/ GFCI - Intex
