Results 1 to 19 of 19
Thread: Pool clear but not crystal clear
    Jul 2014
    Deptford, NJ
    27
    Pool was crystal clear then all of the sudden I noticed it was clear just not crystal like it should be
    Here are my most current readings
    Cya-50
    FC - keeping at 7
    Ta -90
    Ch - 90
    Ph 7.8
    The only big change from the last time I checked all my numbers is the ph is higher. Any suggestion? Should I SLAM?
    Thanks
    20' round AG, 9,500 gal
    150 lb sparco sand filter
    1hp hayward pump
    Taylor k-2006 test kit
    Jun 2014
    15,176
    Re: Pool clear but not crystal clear
    A SLAM certainly is a possibility. Better to knock it out early if needed. I would suggest you perform an OLCT and check/post your CC (combined Chlorine) levels. Together, those may help to confirm your suspicions.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    I have found that a higher than normal PH for my pool will take away some of the sparkle.
    Lower your PH to 7.5 and run a OCLT. That should help you see what might be going on.
    Kim
    Jul 2014
    Deptford, NJ
    27
    My CC is currently 0 ( just tested it)
    My FC is 6.5 tonight at 9:30pm, I'll post my FC for tomorrow AM.
    What kind of overnight loss would I look for to SLAM? And what is that overnight loss telling me is going on?
    Also should I be running 24/7 until I get the problem fixed ?
    Thanks for all the help
    1hp hayward pump
    Aug 2013
    Arab, Alabama
    422
    If your FC drops more than 1 ppm that indicates organics are in your pool and you need to SLAM the pool. During the SLAM run your filter 24/7.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would lower PH to 7.2-7.4 and see how that goes. My pool is a little nicer with lower PH.
    Here is a write up of the OCLT, Pool School - Perform the Overnight FC Loss Test (OCLT), it will tell you if there is organic matter in the pool consuming chlorine.
    I don't think you need to do it.
    Casey's Avatar
    SW PA
    10,448
    How'd the OCLT go? We're breaking daylight n you should have already performed the test.
    Jul 2014
    Deptford, NJ
    27
    FC was still 6.5 this morning at 7:00
    1hp hayward pump
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Maybe a filter cleaning is needed
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    Hebron/CT
    10
    I agree with the filter cleaning. When my DE filter got full water seemed hazy. Cleaned filter new DE and 2 days later sparkly again
    If your chemistry checks out and no signs of algae for SLAM then check the filter.
    22x40 mountain lake design, 24,800 Gallon, vinyl IGP. Pentair Intellipro XF 3 HP variable speed pump, STA-RITE S7MD60 Modular DE Filter, Aqua Comfort Electric Heat Pump. TF-100 test kit
    Jul 2012
    Tallahassee, FL
    30,539
    Sweet! Just work on your PH and see what your water looks like after that.
    Kim
    Jul 2014
    Deptford, NJ
    27
    The sand in my filter was changed last year. I recently backwashed and my clean psi is 17 and the current psi is 18.
    I'm going to lower the pH and see what that does.
    Thanks for all the help and I'll update later
    1hp hayward pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Funny as it sounds, a dirty sand filter actually works better than a clean one. I usually add Cellulose Fiber DE replacement powder to my filter after I backwash.
    Check out this article in Pool School - Add DE to a Sand Filter
    Support the site
    Jul 2014
    Deptford, NJ
    27
    Yea I've heard that too, I try not to backwash too often. I've tried the de in the filter before but every time I do it the pressure rises after an hour or so and I have no return pressure back into the pool. Almost like the filter is dirty again. I wasn't adding much, about 1 cup total, but it just didn't seem right. Should I try with less de? If I see a rapid rise in pressure is that telling me my filter is catching the smaller particles?
    1hp hayward pump
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by nuce70 View Post
    yes, you only add enough DE to get a 1psi rise in pressure.
    Support the site
    wjr75's Avatar
    Jun 2013
    IL
    836
    I can tell when I need to add acid to lower the PH by almost just looking at the water. In my pool the lower PH makes a difference.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    from the other posts I've read, you might only need 1/4 lb of DE. Just put in a small amount, like a few tbls., and watch your psi. Like Tim said, you are looking for a 1 psi increase.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2014
    Deptford, NJ
    27
    Looks like the ph worked ... Got it down to 7.2 and this morning the water already looks better
    Thanks
    1hp hayward pump
    May 2014
    Franklin, NC
    9,184
    Thanks
    Great!
    Support the site
