Thread: Bad Check Valve - Spa drains when we turn it on?
    Jun 2015
    Houston, TX
    2
    Hi,
    New to pools.
    I have a pool with a spa. Today when we turned on the spa it drained after about 5 minutes of use and hot water ended up in the pool. I think I may have a bad check valve? . The springs in the upper left are rotating and rusted like they are broken. Let me know what you guys think. I was planning to replace it myself from leslies to keep costs down.
    It appears I need a 2" Jandy Valve
    Here is a link to a video of the valve
    http://youtu.be/UFa81VtXbgs
    Casey's Avatar
    SW PA
    10,453
    Re: Bad Check Valve - Spa drains when we turn it on?
    I'm sure someone with more knowledge on this issue will be along shortly to assist you.
    Welcome to TFP.
    Jun 2015
    Houston, TX
    2
    Quote Originally Posted by Casey View Post
    Welcome to TFP.
    Replaced the valve for $39.99 (they also call it a flapper valve) and problem is fixed.
    Jun 2015
    Wildomar, California
    423
    Sorry to not get to you quicker but to confirm: Yes, that is called a Jandy check valve and easy to replace.
