Thread: Second issue with our Hayward H400ED2 pool heater
    Jun 2015
    Manahawkin
    6
    Our first issue with this unit I resolved 2 weeks ago or so with the help of you folks here. I was getting an IF code and wound up replacing the damaged igniter, that didn't do the trick so I bought a new control panel from Pool zoom and it worked like a brand new unit, until today. I didn't use the heater for a week or so because of some rain and the weather was hot. I selected the temperature setting (we have a digital control pad). The heater sounded like it tried to ignite once and then threw an LO code that won't be cleared. Now what? I looked over the manual and it's showing everything from insufficient flow, to some electrical issues. I cleaned the skimmer baskets and the basket before the return into the filter. I back washed and rinsed the filter and same "LO" code. Any suggestions before I just break down and call somebody to fix it?
    Bob
    Jun 2015
    Manahawkin
    6
    Re: Second issue with our Hayward H400ED2 pool heater
    **UPDATE** I back washed and rinsed 4 or 5 inches out of our nearly 30,000 pool this past hour and the heater works. Back washed 3 separate times before dumping the last big amount out. Anyway it's working. We had a bad wind storm a few days ago that loaded the the pool with pine needles and lost power for nearly 2 days so the sand in the filter must have been pretty dirty.
    Just an FYI
    Bob
    Orlando, FL
    690
    Thanks Bob, that info will be useful to someone in the future. I am glad you got it working!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
