Results 1 to 7 of 7
Thread: Help with Bugs
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    Help with Bugs
    Not sure what to do, Have these backswimmers in the pool and can't seem to get rid of them. Caught about 40 today and they are driving me crazy. Kids won't get in the pool. Talked to my neighbour who has a pool and has never seen them before. Everything is in check with the pool....not sure what else to do but am at my wits end. Suggestions
    21K Gallon, IG Vinyl, Hayward 1HP Superpump, Hayward 425 sq ft Cartridge Filter C4030 (flow rate 150GPM), Hayward Aqua Rite SWG, Hayward 250K Gas Heater
    Completed Oct 2013 in Vancouver, BC
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Help with Bugs
    They will die off if you FC is high enough. Every once in a while a few will try to move into my pool. I just push my FC up to SLAM level overnight and they die.
    I think mine come to visit from the pond.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Help with Bugs
    Adding borates is said to help and make your water nicer. Here's how, Borates - Why and How
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    Re: Help with Bugs
    Quote Originally Posted by pooldv View Post
    I have borates in my pool about 50ppm, not helping at all. I had my FC at 9.5ppm when I checked last night wanted to bring it back to target level so turned the SWG down from 20% to 15% and ended up having about 40 of those buggers today. It seems the hotter it gets the more we have, I have actually watched them fly into the pool. Just so frustrating. I have now turned the SWG back to 20% to see if that helps. Was not what I envisioned when I put in a pool. Why do they like my pool over my neighbours...just doesn't make sense.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Re: Help with Bugs
    Quote Originally Posted by Queenbee View Post
    ............ Why do they like my pool over my neighbours...just doesn't make sense.
    It makes perfect sense, your neighbors pool is probably full of pool store garbage. See, even the bugs know that a TFPC pool is the nicer pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Oklapoolma's Avatar
    May 2015
    Northeast, OK
    36
    Re: Help with Bugs
    Queenbee, unfortunately Dom is onto something with their preference in nice, clean pools. These bugs LOVE my pool also. I'm certainly no expert, but interestingly, though, I live in Oklahoma where I researched is part of a specific belt of areas where these things tend to be more of a nuisance (especially June/July/August). Now I have yet to give borates a shot as pooldv has suggested, but I am about to. I don't care what it raises or lowers, lol. So, to sum it up, I feel your pain. The only thing I may do as a quick fix is add a squirt or two of dawn liquid to my brush and brush it along my tile/surface as I clean. It will help kill the buggers instantly, but again, it is just a short fix and not a true solution. That said, my TA and CH numbers are also usually waaay high, where they shouldn't be. That must have much to do with it? I cannot possibly have algae. But I must. Somewhere. Either that or I'm just obsessive about them sharing my pool and I'm being a total wuss. Anyway. Good luck and keep fighting the good fight!
    "BOOMER!"
    •21,000 gallon inground gunite pool
    •Pentair-PacFab Triton II Sand Filter -TR100 •Pentair-PacFab Triton Purex Challenger 1.5 H.P. Single Speed Pump
    •Taylor 2006 test kit •Dolphin Nautilus-99996323
    Apr 2013
    North OKC Area
    300
    Re: Help with Bugs
    Just keep the pool clear of other bugs and hope they get hungry and leave for food.
