Thread: pool light with no screws
    Has anyone ever seen that?
    It is an old fixture with a cracked lens that still works but I can't see how to get it out to clean and repair it. The bezel is brass and it appears to be caulked in.
    25,000 Gal In ground
    Ceramic Tiled
    FKAA (Municipal) Water
    Sand Filter
    ! Hp No Name Pump K2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: pool light with no screws
    The only other light I've heard of is one that is removed by turning an eighth turn counter clockwise to remove it. There should be indentions in the bezel to push on with a screw driver to loosen it.
