Results 1 to 8 of 8
Thread: Increase TA?
    Dec 2014
    Riverside California
    482
    Increase TA?
    Hello all. My TA is at 70 right now. My pool seems to use a lot of acid to keep PH at 7.5 or so. If I added some baking soda according to the pool calculator to raise my TA to 80, would this decrease my muratic acid usage at all?
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2011
    Long Beach, CA
    2,789
    Re: Increase TA?
    No, it will actually cause it to use more acid. How much acid are you using?
    Dec 2014
    482
    Re: Increase TA?
    Probably 3/4 gallon per week. I do have a raised spa with spill over. I understand that this can cause PH to rise.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: Increase TA?
    Don't raise TA. And if you can reduce the flow from the spa - throttle back on the amount returned - it will also slow the pH rise.
    Jun 2011
    Long Beach, CA
    2,789
    Re: Increase TA?
    You are using a good amount of acid and there might be some ways to reduce it. Reducing the amount of aeration is the first step and targeting a higher pH will be the next step. The pH will rise slower when it's near 7.8 and you should see how long it will stay at 7.8.
    To cover all bases, how old is the plaster?
    Dec 2014
    482
    Re: Increase TA?
    I do have a 2 port ball valve that controls the amount of return to the spa (in pool mode). Based on your replies, I have turned the valve so that maybe 1/3 of the water going to the spa remains. This is just based on observation of the "waterfall" going over the spa spillover. I knew that aeration would increase PH, but also knew that shutting off all the water to the spa was not an option. Didn't think about just reducing the spa flow (DUH). Thanks for the replies and tips!
    Jun 2011
    Long Beach, CA
    2,789
    Re: Increase TA?
    I have my spa adjusted so the water just trickles down the side to eliminate any splashing. Keep an eye on the FC level in the spa for the next few days to make sure it is getting enough water exchange.
    Dec 2014
    482
    Re: Increase TA?
    Reduced the flow to a level to minimize splashing. Will check my daily PH readings and see how much this helps. Thanks again, everybody for all the tips!
