Thread: New from SK, Canada
    Jun 2015
    Swift Current, SK, CA
    16
    New from SK, Canada
    My husband and I are looking into above ground pools for our acreage. We have well water with a high mineral content but safe to swim in and drink. We have never had a pool before. And are fairly clueless, hence why I have signed up.
    Jun 2014
    14,980
    Re: New from SK, Canada
    Hello and welcome! Glad to have you with us. If you haven’t done so already, take a moment to read some of our most common and vital links (below in my sig) to keep you ahead of the game with clear water. Also, make sure you have one of the recommended test kits (i.e. TF-100 below) as well. Actually in your area, you would need to order the Taylor K-2006. It is an absolute “must” to obtain the proper chemical readings before you can treat your pool.
    Well water brings iron, but we have posts on that subject to assist you. But without a doubt, the test kit should be priority #1. Welcome to TFP, and have a great weekend.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    6. Test Kit Comparison
    Casey's Avatar
    SW PA
    10,422
    Welcome to TFP
