Results 1 to 7 of 7
Thread: Little chlorine and nitrates at 43
    Jun 2015
    Fairfield,New Jersey
    3
    I have little chlorine and was told by Anthony Sylvan pools to,empty my pool to,get rid of nitrates.My pool contractor told me to add about 10 gallons of household bleach tonight and super chlorinate with 10 lbs of granular chlorine.I don't want to raise my CYA too high and added 4 lbs of shock today is 10 gallons of bleach tonight too much for 27,500 gallons..I Do have mustard algae in some areas.
    thanks
    bob
    My pool,is 27,500 gallons,gunite is 34 years old and has a heater
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Little chlorine and nitrates at 43
    Welcome to TFP!
    The first decision you have to make is whose advice you are going to follow. As you can see you are getting different suggestions, and I can tell you neither of them match how we would suggest you handle it.
    Support the site
    38,305
    Welcome to TFP!!!
    Nitrates are meaningless as are phosphates in a properly chlorinated pool. Blindly adding that much chlorine is NEVER recommended by TFP as it could cause damage.
    If you want to take control of your pool, you need to invest in one of the Recommended Test Kits and then post a full set of test results.
    The TFPC method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS.
    Jun 2015
    3
    Ordered a test kit will arrive next week,will add a couple of gallons of bleach tonight to see if I can raise th chlorine level,so far CYA seems to be okay,also added 4 lbs of shock today.
    May 2014
    Franklin, NC
    9,184
    Anytime I see pounds of shock I get nervous. That shock is bringing along CH or CYA and without a test kit you don't know if you need any of either one. I would stick to liquid until you get your test kit.
    Support the site
    Jun 2015
    3
    Okay,the chlorine level is finally normal high,will check cya tomorrow at pool store and see if it is elevated,will use bleach until I get the test kit.
    thanks
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    Quote Originally Posted by boboz View Post
    thanks
    CYA takes approximately a week to show up on tests, even though it is in the water and you should treat it as being there for your chlorine level
