Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Advice on Intelliflo V/S
    Dec 2014
    Houston, Texas
    62
    Hello Everyone,
    I am leaning towards replacing our current pump, which is a Whisperflo single speed 2.5HP model (see pic), with a variable speed intelliflo 3HP model, such as the one below:
    Amazon.com : Pentair 011018 IntelliFlo Variable Speed High Performance Pool Pump, 3 Horsepower, 230 Volt, 1 Phase - Energy Star Certified : Swimming Pool Water Pumps : Patio, Lawn Garden
    Using back of the envelope calcs, I figure my energy savings would be roughly $20/month (depending on how it's ultimately setup of course), but would provide other benefits such as being quieter, having freeze protection, and being able to run the pump longer at a lower speeds in order to keep the water moving. So it's not all about immediate financial payback as I know that will take some time given the purchase price.
    Would there be any issue replacing my current model (2.5HP) with this one (3HP)? My old model is 230V so I think in terms of electrical it's no problem (assuming I don't electrocute myself). Also, the pump today is hooked up to the intermatic timers so could I bypass those with the new pump?
    Thanks for everyone's help.
    28k gallon AG pebble sheen, Pentair Triton II Sand Filter, Intelliflo 3HP, SWG, TF-100 test kit, spa
    Pool installed 2005/2006 (we bought house in summer 2014 so our knowledge of pool history is limited)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Advice on Intelliflo V/S
    Do you have solar heating panels, water features or other plumbing items that make that much HP in a pump necessary? Some more details on your pool would help in that area. Your current pump may be oversized already and you might be able to save even more on your electric bill going with a lower HP VS or two speed pump.
    Isolated Spa - 345 Gallons
    Dec 2014
    Houston, Texas
    62
    Quote Originally Posted by JVTrain View Post
    @JVTrain - Thanks for your response - I do have a spa attached the pool which this pump would need to power, but that's it. I think the 3HP is the only model intelliflo has. Obviously being V/S you can dial it down to the needed rate so not sure the max power is that important - perhaps I'm wrong here.
    mas985's Avatar
    Pleasanton, CA
    11,742
    There are several VS models from Pentair including the Intelliflo i1 which is a lower HP version. But instead of that, I would consider the SuperFlo VS at a much lower price point.
    But a two speed would likely save you just as much if not more over the life of the pump since the up front costs are much less.
    Mark
    38,526
    You don't think the Superflo VS will be too weak for the spa?
    I would think you would want to stick with a 2-speed version of a similar Whisperflo that you have ... anything wrong with the pump? Might just need a new 2-speed motor.
    Or get the Intelliflo VS, but that seems a little overkill for your needs.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Personally, I think this is a perfect application for the intelliflo pump. Also, I'm pretty sure you will save a lot more money than you think. By only running your schedules during off peak hours, it helps you save in energy costs. Also, cash in on the rebates offered by your utility.
    I recently replaced an old power hog 2.5hp pump at my brothers house. With better scheduling and reduced speeds on the pump , he says he saves about $80- $100 per month... But his is an extreme case.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yes it would. I missed the comment about the spa. But I would agree that a VS is overkill. I would just replace your current motor with a two speed.
    Mark
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by mas985 View Post
    Trying to learn myself in this thread. So a 2.5 HP WhisperFlo 2-speed motor end might be the ticket? Lower upfront cost for 2-speed, electricity savings?
    Dec 2014
    Houston, Texas
    62
    @jblizzle - there is nothing wrong with the current pump, but it seems like if I'm going to invest in a new pump ($400), I might as well spend a few hundred more and get some of the features I want with the new pump (i.e. freeze protection - believe it or not it does freeze in Houston and it can create problems).
    Dec 2014
    Houston, Texas
    62
    Maybe this is a dumb question, but if I just replaced the motor on my current pump with a 2 speed motor, how do I actually control the speed? Doesn't it need the higher speed when it is first turned on, but can then run at a lower speed to keep the water moving? Do you have to go to the pump every time and manually adjust the motor speed?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Manual switch OR two speed timer OR electronic controller.
    No unless the pump loses prime which it shouldn't.
    Not if you get a two speed timer. But given the size of the pump, you shouldn't really need high speed unless you are running the spa. You can just run on low speed all the time and then switch manually to high speed for the spa. You have to change the valves anyway, right?
    Mark
    Dec 2014
    Houston, Texas
    62
    Honestly, I'm not sure. I don't have any experience with this so trying to learn as much as I can and figure out what is the best long-term solution.
    I should also point out the existing pump is probably 8-10 years old at this point (not sure what the typical lifespan is).
    mas985's Avatar
    Pleasanton, CA
    11,742
    Motors last upwards of 10 years but the wet end (actual pump) lasts much longer. There is not much to go wrong with a pump other than a cracked housing which is usually because of freezing. Everything else can be replaced.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I love my 3hp VS pump. It is way more pump than I need. It can also do everything I have ever wanted it to do. And it has save me tons of money.
    My pump runs solar, filter, skimmers and waterfall.
    1100 rpm gives me good skimmer action and runs my SWG. The pump draws 150 watts at 1100 rpm. So, during spring and fall I can run it 24x7 to keep leaves, pollen and tree stuff skimmed and off the pool floor.
    It runs my solar panels at 1950 rpm and 550 watts.
    It runs my waterfall and skimmers at 1500 rpm.
    And solar plus waterfall at 2500 rpm.
    I also use 2500 rpm and all main drains to brush the pool.
    I never get close to the max rpm of 3450.
    I will buy another when this one fails without hesitation.
    Jan 2012
    340
    Quote Originally Posted by pooldv View Post
    This.
    You're not looking at too much more money to go to the Intelliflo versus a 2 speed, not including the extra money/effort you'll put into a 2-speed switch.
    - Ability to vary your speeds anywhere in the RPM range(not just full speed and half speed)
    - Much quieter motor at all RPMs
    - You are probably WAY underestimating your power savings
    - Sealed, aluminum construction motor
    - Freeze protect (although this is to protect electronic components, not prevent frozen pipes)
    - Simple automation integration if you upgrade to controls in the future.
    This is a no brainer. Get a couple high temp unions to install the new pump and you're golden.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Sep 2014
    Bakersfield, CA
    155
    I too love my 3HP VS pump, and feel the versatility of this pump is well worth the few extra bucks. The OP may want to consider the IntelliPro rather than the IntelliFlo. I think there was a recent thread on the differences between the two pumps but if I recall correctly you set a given water flow rate on the IntelliFlo and the pump then adjusts the rpm to maintain that flowrate. The drawback to this is that as the filter gets dirty and back pressure increases; the pump automatically increases rpm to maintain flow and power consumption increases accordingly. On the IntelliPro you just set the speed and that's it.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    mas985's Avatar
    Pleasanton, CA
    11,742
    The Intelliflo VS and Intellipro VS drives are identical except for color. What you are describing is the difference between the VF and VS. VF is variable flow (set GPM) and the VS is variable speed (set RPM).
    Mark
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    I agree that the intelliflo would be way overkill, but I have an intelliflo and its way way overkill for my small pool.
    Its an awesome pump. Man its just so versatile. If you arent worried so much about the upfront cost vs recovering your investment in a reasonable amount of time, then certainly consider it.
    Im with pooldv, in that if mine died tonight, I would put another one in.
    Divin Dave,
    Jan 2012
    340
    Intellipro VS and Intelliflo VS are different pump designs. Intellipro is based off the Max-E-Pro platform.
    Newer pump design, built in unions, less prone to seal plate issues, but why hassle with the re-plumb when an Intelliflo will drop right in.
  20. Back To Top    #20
    Dec 2014
    Houston, Texas
    62
    Quote Originally Posted by thepoolman View Post
    OP here...appreciate everyone's feedback. Very interesting to me that there are two distinct schools of thought on the topic. Honestly not sure what to do at this point. The people that have the Intelliflo clearly love it, while if I just switched out the existing motor it would still cost me over $400.
    Assuming we went with the new pump, how difficult is it to swap out? I'm somewhat handy but not great. Existing setup seems pretty straightforward, although we are currently hooked up to the timers as I originally pointed out.
    Thanks again everyone.
