Thread: Another "What is on my walls" question. Just acid-washed...
    Jun 2013
    Las Vegas, NV
    7
    Hi,
    Just got through acid-washing, in hopes of possibly avoiding re-plaster for another few years. I don't have any great "before" pictures handy, but the main thing we were after was to get rid of some dark (black-ish) marks on the pool bottom that kind of looked like someone may have run an automatic cleaner too soon after the original plaster job had been completed.
    The good news is, those marks came out completely!
    The bad news is, there are now some new marks & discolorations which are apparent right now. We hadn't noticed these discolorations, or if we did, they were very minor.
    Maybe it's just because the pool is empty and they're really just minor imperfections that will be hidden once it's filled back up (is filling now)? Or is there something obvious here?
    The pool won't be full again for another 24-48 hours so I won't know til then -- but if there's something I should or could try in the meantime, I'm all ears. If the stains end up being obvious after it's re-filled, then we're going to end up going for the Pebble Sheen (around $6-7k), so I am hoping they either aren't visible when it's full or that they can be removed.
    Pictures can be found here: pool discolorations - Album on Imgur
    (Note that there is some water in the bottom of the deep end of the pool in these pictures)
    ~20k Gallon IG pool/raised spa combo. White plaster, newly acid-washed. Pentair VS, Pentair Heater, Pentair EasyTouch8, with Autellis control module for integration with home automation system.
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Another "What is on my walls" question. Just acid-washed...
    Was the coping and tiles covered during the acid wash?
    Matt
    Jun 2013
    Las Vegas, NV
    7
    The tiles were acid-washed as well, and we followed that up by brushing them to remove the water line build-up that was on them... The cool-decking part was not touched by acid / not acid washed at all.
