Results 1 to 8 of 8
Thread: 0 cya 0 fc
    Apr 2015
    porter Tx
    26
    0 cya 0 fc
    **We have and above ground, sand filter, Hayward pump. 15,000 gal. **
    Before we went on vacation I shocked our pool. Luckily my tf 100 test kit came in while we were gone! My sil ran our pump every night. Came home, the pool is green. Or readings are 0 cya and 0 fc with the highest rating on the ph. I know we need to get some stabilizer to raise the cya. But I do not understand the chart in pool school on how much shock I need to buy to slam my pool. So if it says 10, is that 10 gallons? Please forgive my ignorance in this I'm still a newbie!!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: 0 cya 0 fc
    Welcome to the forum.. You need to get your PH in mid 7 range before anything else. Green pool = SLAM per Pool School. Please add a signature line to your profile like mine below detailing all your pool specs and equipment so we can help. Take your CYA level to 30 and SLAM at that level using plain old bleach per the cya'/chlorine chart. PoolMath is your friend.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: 0 cya 0 fc
    You need to use Pool Math: http://www.troublefreepool.com/calc.html Input your volume it will calculate additions for you. Your Now FC is 0. Your target is 10. If I input those values, I get 222 ounces. Which is about 1.75 gallons. See if you can replicate that using Pool Math.
    You should get some CYA in your water first, up to 30 ppm, then SLAM at 12 FC.
    What test kit are you using? - EDIT: I see the TF-100...
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    Re: 0 cya 0 fc
    Youve got the right kit to test. Now you'll need to learn to raise your pool up to "SLAM level" and KEEP it up there for as long as it takes to go from green to clean.
    Its a process, not a one time dose.
    If you have 30 ppm CYA, your SLAM level (aka shock level) is 12ppm chlorine. The Pool Math app (found in Pool School) will help you keep your pool at 12ppm because once you put that initial dose of bleach in the water, keeping the filter running at all times, you'll wait about an hour and retest your chlorine level. If its down to say 9, you'll enter that number in to the Pool Math app and then input your target goal of 12 and it will tell you how much MORE bleach to add to get it back up to 12.
    The algae in your pool is actively reproducing but if you keep your chlorine up to the 12, brushing the pool and running the filter, you'll start killing the algae off faster than it can reproduce. It may take a few days or a week or more....the more often you test and dose with chlorine as it deminishes the faster it will go.
    Apr 2015
    porter Tx
    26
    Re: 0 cya 0 fc
    Thank you!! I am getting ,started on the pool in the am. Got all the chemicals I need and I'm ready to go!!
    DGS's Avatar
    Jun 2015
    memphis tn
    34
    Re: 0 cya 0 fc
    I am new pool owner too and also had 0 for FC and CYA. I did the slam also-it helped so did poolcalculator.com, as well as the experts on this site.
    I also found the chlorine dispenser wasn't working properly. You might want to check that also.
    Memphis TN New to owning a Pool.Appx. 25,000 gallon inground gunite outdoor pool appx 20x40 curvy shape surrounded by 10 large crepe myrtles and other trees.Pool was installed about 20 years ago.
    Triton II Sand Filter Pentair Chlorinator 3" tabs Polaris vacuum 3' to 7' with a diving board. Taylor 2006 FAS DPD Test Kit
    Apr 2015
    porter Tx
    26
    Re: 0 cya 0 fc
    I will defiantly check that, th a k so much!
    Casey's Avatar
    SW PA
    10,438
    Re: 0 cya 0 fc
    Welcome.
    Please update your signature as outlined here: What we need to know to answer your questions
    It will help us help you.
