Thread: New member
    Jun 2015
    goldsboro, nc
    2
    I have installed a new above ground pool 24ft x 54" 2 weeks ago. Weather gets hot here in NC. I am using Baquacil chemicals in the pool.
    Jun 2014
    15,012
    Re: New member
    Welcome to TFP! Make yourself at home here on the site and look around. Also remember that here at TFP, the proper test kit (i.e. TF-100 – link below) is the foundation of your pool care. Why this kit? We've learned through personal experience that you cannot reply on pool store testing, test strips, or simple over-the-counter kits. They simply do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K2006 test kit, it should be your #1 priority.
    Happy to have you here at TFP.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New member
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    6. Test Kit Comparison
    Casey's Avatar
    SW PA
    10,424
    Re: New member
    Welcome. Please reconsider using Baquacil in your Pool. We have a Baq section but its mainly because people are tired of the expense and having problems keeping the pool clean.
