Results 1 to 7 of 7
Thread: Skimmers and Drains
    Apr 2015
    Quinlan, tx
    811
    Skimmers and Drains
    I would like to make some adjustments to the powerfulness of the skimming (if it's even possible). I don't feel like our pool skims well from the top. I don't know if it has anything to do with the deepness of our pool so the main drain is 8.5 deep below. I've been a good student of TFPC pool chemistry and have that down so now I'd like to fix a few other things to help out with the general appearance. Is what I'm suggesting even possible?
    Thanks in advance for any guidance!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Apr 2010
    Central NJ
    227
    Re: Skimmers and Drains
    I tend to have that issue when the pool is "too full", e.g. after a couple of inches of rain. I tend to keep my water low (lower half of the skimmer) so that I can get as much skimming as I can. If that doesn't work for you, do you have a valve or valves before the pump where you can adjust where to "pull" the water from?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Jun 2014
    15,008
    Typically if someone wanted to increase their skimmer strength (for surface water cleaning), they would look to their plumbing controls. Some pools have a 3-way valve on their suction side just before the pump basket that allows them to adjust how much suction they want coming in from either the main drain versus the skimmer(s). If you have such a valve, you could try adjusting that.
    May 2015
    Chickasha, OK
    184
    I have had that problem since I "inherited" my pool when I bought my house.
    Come to find out, one of my two skimmers didn't have a weir (flap), and the other was badly damaged and might as well have not been there. I just replaced them last night, and the skimming action is much, much better.
    After you check your 3-way valve, check your weir(s) and make sure they're in place and working as they should.
    Prior to purchasing new weirs, I tried a product called the Skim Doctor. It's supposed to create a vortex in your skimmer which improves skimming action. Unfortunately, my skimmer baskets sit so low in the water that I didn't see any benefit from it. I believe the product is a sound design, but it just didn't work for my particular application.
    If you try everything that's been suggested so far in this thread and still want/need more skimmer action, PM me your address and I'll gladly ship this Skim Doctor to you, no charge.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Apr 2015
    Quinlan, tx
    811
    I think we might have the valve. I'll check when we get home and also the wiers. Then I'll post back Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    You do have the valve. I remember seeing it in your SLAM.
    Not Sure Where to Start - Or What We Are Doing Wrong - Page 3
    The pic in post 60 with your equipment
    The two valves in front of your pump to the right of the motorized valve (that probably switches between spa and pool). My guess is the valve on the right will turn off flow from the bottom drain if you turn it so that the handle points to the left.
    Apr 2015
    Quinlan, tx
    811
    Skimmers and Drains
    Thanks pooldv! Good memory!
