Thread: 3 Port Valve Pentair Valve Actuator Question
    Apr 2015
    Quinlan, tx
    811
    One of our actuators went out. My husband ordered a new one and replaced it just fine. However, the setting isn't right for our system. I"m probably not explaining this well. We have an spillover spa and a separate water feature that are effected by this valve. Before we replaced the valve, the spillover spa came on whenever the pool filter was on AND when the water feature was in. Now it isn't coming on. My husband took the old actuator a apart and he can see that the internal mechanism is not set the same way on both actuators so we need to adjust the new to the same position as the old one. Does this make any sense and can anyone help?
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Apr 2015
    Quinlan, tx
    811
    Re: 3 Port Valve Pentair Valve Actuator Question
    Never mind friends, my husband thinks he has it figured out
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Good news! If he doesn't send him back to Pool School!
    Yes, just need to adjust the cam stops to start and stop the valve in the right spot. Sounds like he is on the right track.
    Apr 2015
    Quinlan, tx
    811
    Yeah. He told me to look it up, but before I got an answer, he figured it out. Guess being an airplane mechanic helps 😉
