Thread: Pressure gauge for Intex sand filter
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    I think I need a new pressure gauge for my sand filter; the gauge never moves. It will register 0 with the pump off but when the pump is on it never goes above 5. It's the gauge that originally came with the system. Given the fact that Intex has proprietary sizing on all of their equipment, I am wondering if the gauges sold on the tftest kits site will work. Has anyone here used one of these gauges on an Intex pool?
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Pressure gauge for Intex sand filter
    If you turn off the pump, shut off the valves and unscrew the pressure gauge you should be able to see if it is a 1/4" or 1/2" shaft. I believe 1/4" is the standard size.
    Love TFP? Become a
    TFP Supporter!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,549
    Yes, I got one. I had to get a bushing at the hardware store, seen below, to adapt it to fit the Intex filter.
    My tftest filter only shows 5-6 lbs pressure after a backwash, so your Intex gauge may not be that far off. But it's a nice, cheap upgrade anyway.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Thanks for the info! I was afraid if I got one and it didn't fit, I wouldn't know how to make it fit. I see that it is a simple fix!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,549
    Yeah, it was less than $2. Just take your old and new gauges with you and ask a clerk to help you find something to make it fit.
    Pentair IC40 SWG
    domct203's Avatar
    Jun 2015
    CT
    3,593
    I've replaced my Intex gauge with this one:
    http://tftestkits.net/Pressure-Gauge...Mount-p78.html
    You will need an 1/8" MNPT X 1/4" FNPT adapter, as shown in the pic posted by jeffchap.
    The gauge is very good quality, and much easier to read than the original.
    BTW- my clean pressure is about 9-10psi.
    If you decide to take both gauges with you to the hardware store be sure to isolate the filter so it doesn't drain the pool through the open pressure port.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
