Results 1 to 12 of 12
Thread: Cloudy Pool
    Cloudy Pool
    I started the SLAM on Monday. I was on here last year and you guys helped me through it. My CYA is 50 and I have been keeping it above 20 since Monday. Wednesday it turned cloudy blue and rose 1 pressure. The last 3 days I haven't been seeing a notice in clarity and the pressure has been staying the same. My filter is pretty efficient. Last years slam cleared up after 2 days after being blue. When I opened the pool it took only 3 days to go from green to clear. I notice for the past 3 days that the filter pressure hasn't gone up. This morning I backwashed it, hoping that if there was some channeling or something else going with the filter it might fix it. Do you think I'm just being impatient? Should I just give it a few days?
    16x32X8 Vinyl liner 21,000 gal.
    Hayward Pro Series S220T 250lb. sand filter hard plumbed
    Taylor K-2006 Test
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Cloudy Pool
    SLAM process can take a bit. Just be patient and wait it out.
    Can you post a full set of results please?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Re: Cloudy Pool
    FC: 22
    CC: <.5
    PH: Can't measure but was on the low end when I started.
    Taylor K-2006 Test
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Cloudy Pool
    Give it time. It will get there. Bring it up to shock level, give it a good brushing and then find something to do to take your mind off of it. Mahoney State park is nice. Or, drive over to Ashland. The Glacial Till Vineyard has a neat tasting room. Have a nice glass of Nebraska wine and relax. Walk next door and check out the Willow Point Art gallery. Gene Ronka is a really good artist with some neat local artwork.
    By the time you get home it will be time to test and adjust the FC again.
    Support the site
    Re: Cloudy Pool
    Well I spent my time at Wanahoo lake all weekend, coming back and forth. I can see the main drain now. It is still taking forever though. Its going to take another week at this pace. I kind of wanted it done by the fourth of july. ugghh. Patience, patience, I guess. Just weird my filter was way more effeicient the last two green pools.
    Taylor K-2006 Test
    Re: Cloudy Pool
    Questions please answer. It was clear finally (still not crystal clear), so I decided to vaccum to waste. I am horrible at vaccuming, so the pool got all cloudy again. When I was done I notice a tiny bit of sand in the leaf catcher and a little bit of sand in the backwash bottle (the thing you look through to see if your backwash is clear). My pump is about 2 PSI more (18 PSI) than normal of 16 PSI. What are the symptoms of a filter that is leaking sand? I know it has taken forever to clear but it has cleared some bit each day. Do you think it was just sand at the bottom of the pool from other source other than the filter. My pool was pretty dirty on the bottom. Something wrong with the filter would explain why it was taking way longer to clear the pool than usual.
    Taylor K-2006 Test
    May 2014
    Franklin, NC
    9,184
    Re: Cloudy Pool
    How are your other numbers looking?
    What is your CC and have you completed n OCLT? Clear pool is only one of the three things you have to pass.
    Support the site
    Re: Cloudy Pool
    Fc: 23
    cc: < .5
    Taylor K-2006 Test
    Re: Cloudy Pool
    I went to where it goes to waste and there is a lot more sand. I started tapping on the filter and it gives way from the top to almost little below half way. So I am guessing the sand is about to halfway in the filter. Is that not right?
    Taylor K-2006 Test
    May 2014
    Franklin, NC
    9,184
    Re: Cloudy Pool
    Quote Originally Posted by Zegster View Post
    Google your sand filter and take a look at the manual. It should give the information on what is "full".
    Support the site
    Re: Cloudy Pool
    The how to online says to fill up to half way. So maybe I'm good. I'll keep an eye on it. This morning it looks a little clearer than yesterday and PSI went up a smidge. Still worried about a crack in the filter though.
    Taylor K-2006 Test
    Re: Cloudy Pool
    I got in and in front of the jets there are some small piles of sand. I guess on Monday I'll call the pool store. Be like 3 weeks before they can get out. Two years in a row I haven't been able to use my pool to August almost. Ridiculous. House might be on sale soon, if anybody is looking to buy in Lincoln. Look into bulldozing the thing too. I've spent about two full time weeks on this thing and still have yet to swim and its July.
    Taylor K-2006 Test
