Thread: effect of soap on pool water
    Mar 2009
    Charlotte, NC
    539
    Not interested in full body lathering up then jumping in the pool, but what effect does soap have on the water chemistry? Soap should be avoided? Some is ok? I soap up & hose off but wonder how good good of a "hose off the soap" is needed? Thank
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    22,551
    Re: effect of soap on pool water
    While you should definitely hose off, a little soap isn't going to make much difference in the pool.
