Thread: Skimmer install in 18'x48" Intex AGP, what to do with two outputs?
    Jun 2015
    Decatur, IL
    3
    I recently put up an 18'x48" Intex AGP that has two outputs and one return. I tried out the Intex hang on the side skimmer and couldn't get it to work at all. The side frames of my pool are oval and the thing kept slipping off. Also, the skimmer wouldn't stay under the water. Total garbage. So I returned it and bought a through wall skimmer. I didn't even know you could install a skimmer in an Intex pool that didn't come with one installed already until I found this site. Excellent information here!
    The question I have is what do I do with the two outputs that came standard in the pool? I thought I could continue to use one and put it on a ball valve and tie it in with the skimmer output. Not sure what to do with the other one though. Anyone have any suggestions? Thought about using the other to tie into a second pump and run it up to the pool for a DIY fountain. Anyone have thoughts on if that was a good/bad idea? Any other thoughts on what to do with the two outputs?
    Also, how far away from the two outputs and input should I install the skimmer? Does it even matter?
    Any help you guys can give would be most appreciated!
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: Skimmer install in 18'x48" Intex AGP, what to do with two outputs?
    Welcome to TFP.
    While I have the original 1-suction version, here is a link to my skimmer install:
    http://www.troublefreepool.com/threa...ltra-Frame-AGP
    This will give you some ideas on how to install and plumb.
    I only use the original suction port for my vacuum, and use the skimmer only for daily filtering.
    HTH,
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    Decatur, IL
    3
    Domct203, your skimmer install is where I got the idea to connect the one output with the skimmer drain! I wonder if you can have them both working to pull water from both the middle and top of the water column?
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Just in case there are readers reading this wondering about getting the side skimmer, I have it and it works great. It has never floated up for me. It is such a time saver. I'd recommend it to anyone.
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    Jun 2015
    Decatur, IL
    3
    I would just caution anyone wanting to buy the side skimmer to read the Amazon reviews for it. Seems like an aweful lot of people have the same issues with it that I had. Of course, a lot of people had no issues, as well. I like the idea of a through wall skimmer more anyway, now that I know it can be done safely.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by elmatth1 View Post
    Yes you can, and I do that when I have swimmers stirring up the pool, but I find that I loose a lot of "draw" from the skimmer. For everyday filtering I use just the skimmer, it works great. Much better than that floating type intex skimmer.
    Dom
    Dom - TFP Guide
