Results 1 to 10 of 10
Thread: New pool accessory
    Aug 2007
    SE Louisiana
    16
    New pool accessory
    Found this in pool after very cold night. Guess he's looking for a warmer place than the ponds or rivers around here when it gets real cold. At first thought he was trapped in pool, but turned out he got out after a few hours of playing and resting on the tubing of the Polaris.
    22x42 Mountain pond vinyl liner w/polymerwalls Custom concrete steps and bench with spa jets
    7' round spa with stepped spillover
    Hayward 1-1/2hp pump and 500lb sand filter
    Pentair booster pump for polaris 280
    Savi 12v LED lights - 3-pool 1-spa (very nice)
    RayPak 8300ti heat pump
    Goldline PS8 contol system (worth every $)w/Aquapod remote (also worth every $)
    Goldline chlorine generator
    Blower for spa jets (a bit overpowered)
    Polaris Deck Jets
    Re: New pool accessory
    cute!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You otter get that thing out of there.
    Casey's Avatar
    SW PA
    10,428
    Oh My God! He is sooo cute and loves your pool!
    way toooooooo cute!!!
    24 x48 above ground pool.
    hayward sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    I agree w/spishex!
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Cool!! Where can I get one?
    Luv& Luk
    -Ted
    May 2008
    florida
    112
    To funny.
    San Francisco Bay Area
    16
    Too cute - I need one for my pool
    11.5K gallon IG gunite - L shaped pool - Pebblesheen finish
    SWG, Intelliflo 4x160, cartridge filter
    Heliocol solar
    Guest
    Does he need a booster pump?
