Results 1 to 12 of 12
Thread: Combined chlorine too low
    May 2015
    Atlanta-GA-
    69
    Hi
    Just getting started here, I actually entered my pool for the first time today, it was great.
    Question about chlorine. I tested with taylor K-2006.
    It says my free chlorine is 1.8ppm and my combined chlorine is only 0.4ppm. I use costco clorox tablets. They seem to take time to disolve, I got 2 tablets in the dispenser. Will that combined chlorine level go up eventually? What ppm does combined chlorine has to be?
    Thxs
    Pat
    12' AG, 3200GA, cartridge filter, pool installed 6/20/2015, Taylor K-2006 test kit,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: Combined chlorine too low
    Pat! CC is BAD! You do not want ANY Combined Chlorine!
    I see you say you are using a Taylor K-2006 BUT how did you get a FC of 1.8ppm and CC 0.4 ppm?
    The CC is the used up FC.
    Kim
    April's Avatar
    Apr 2014
    KY
    138
    CC-.5 or less. You don't want it to be high.
    Post full set of test results please.
    FC
    Cc
    CYA
    PH
    TA
    CH
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Ideally you want your CC to be 0.0ppm, but <1.0ppm is good.
    What you really need to watch is your FC, and without knowing anything else about your pool I would warn you it is too low at <2ppm.
    I see you are using the 25ml sample for a resolution of 0.2ppm. You will be fine using the 10ml sample with a resolution of 0.5ppm, that's close enough for TFPC.
    What at is missing here is your CYA level, which is what dictates your FC level.
    Please se post a full set of test results for FC, CC, CYA, pH & TA so we can better understand your pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    FC is probably low, depending on your CYA level. Set your chlorine level based on CYA level, keep it at target at all times and never let it drop below minimum or algae will grow and the pool will not be properly sanitized. Here is the Chlorine CYA Chart
    Here are your target levels
    http://www.troublefreepool.com/conte...mmended-levels
    Here are the pool chemicals and how to add them
    http://www.troublefreepool.com/conte...pool-chemicals
    Use http://www.troublefreepool.com/conte...ool-calculator to calculate how much to add.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey Pat, Welcome to TFP!
    Take a look at PoolSchool as soon as you can and begin with the ABCs. Free Chlorine is the one you are concerned with first, as it's the one that does the work. CC is the result of FC getting used up, so as mentioned, you don't want a high level of it. Work your way through Pool School, and ask all the questions you need too here. Enjoy your time on the forum.
    Essential Links:
    May 2015
    Atlanta-GA-
    69
    Ok here are some pool numbers I just took:
    PH 7.0:
    -Ph was actually acid but I added 2 lbs of baking soda and it's up. I will add more tomorrow as I think it needs to be higher.
    FC: 5.4ppm
    -I know it's too high. We use Clorox tablets and we had 2 in the dispenser and it tested at 1.8ppm. So we added 2 tablets for a total of 4 and now it's too high.
    CC: 0.4ppm
    -This is unchanged since last test. I don't know how to get it to zero.
    Cyanuric acid 0ppm
    -I have the Clorox stabilizer bottle but I am clueless about how much to add and how much ppm is my goal.
    I haven't added any
    TA: 170ppm
    -Not sure of my goal TA
    Thanks
    Patrick
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Poolmath at the top of the page will tell you how much to add of whatever it is you are looking at.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Dec 2009
    Central Massachusetts
    2,690
    Please don't add anymore baking soda. That is for raising the TA, not pH. Your TA is high enough, too high really.
    You need to read through pool school a few more times before you add anything else.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jul 2012
    Tallahassee, FL
    30,638
    Look at the link below. Print it out and circle the set that applies to your pool.
    Use pool math to see what you need to add and how much.
    http://www.troublefreepool.com/calc.html
    Here is a good link to tell you what to do and add for each area of your water.
    Kim
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Your FC is fine.
    pH is a little low. Adjust up to 7.2 is what I have read around here.
    Your CYA is low but we are going to target 30 so FC around 4-6 is correct.
    For your 3200 gal pool. Using poolmath looking at the CYA line with Now set to 0, Target set to 30. It says 13 ozs of granulated. Put it in an old sock and hang it in front of the return. Give it a squeeze once in a while. Test for it again in a week.
    FC and sunlight remove CC. That's all there is to it.
    May 2015
    Atlanta-GA-
    69
    Ok thanks for the answers.
    I will add Borax and stabilizer today according to pool math.
    Thxs
    Pat
