I have a Aqualink with iaqualink. I recently had issues with a jandy epump prematurely and switched to intelliflo. It was doing so well that I decided to replace my aging booster pump with an intelliflo as well so I could dial in the speed.
Without making any changes, When both Intelliflos are hooked up they "pair" and run at the same speed. I went into the system setup and changed pump 2 to intelliflo, but I don't think that changes anything unless the system detects it as a separate pump.
Is it possible to control both pumps independently through the aqualink? If not, would it harm the intelliflo to set it at my preferred speed and have it on a relay through the system?
